![]() | Home > Maintenance & Modifications > Help: installing Entreq stainless door strips |
Quick question about the washer order (can't get hold of Olaf)...
I've got bolts, nuts, metal washers and (fewer) plastic washers. Is the washer order from above: metal washer, plastic washer, stainless strip, alu floor, metal washer or metal washer, stainless strip, plastic washer, alu floor, metal washer or something different? I know it's all about corrosion but sometimes these things are more complicated than they seem ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Where is the smacked bottom icon when you need it.
Or I could say read the manual! Good job you are in Germany so just hope reading German is second nature to you! Have a read of THIS The plastic washers are for height adjustment. Now do you fancy doing an English translation for us all? Brendan |
Doh
![]() Feel very silly - actually saw those instructions last year but forgot where they were (has taken months to get some decent weather - today). Guess I panicked before the sun goes in ![]() Cheers Brendan - for my sins I will provide a translation (when the weather is bad ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Aha - actually the new MY12 strips don't come with the rubber edging because of the new LR door seals.
Off to play now... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
The plastic washer will use for "level" if necessary the screw ONLY for the plate where you put your feet.
In proximity of the seat, the edge of the battery box increases the thickness regarding the place where you put the feet.... Clear? ![]() ![]() IID Pro MV License |
mhmmm in this case you do not put the silicone entreq seal but only the metal plates.............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks guys
![]() Okay, so I used 2 plastic washers to even out the height at the front. I also used butyl and plastic washers underneath to make a good seal from below. I didn't use the compression band but used butyl tape instead (squeezes into anywhere and never fails) and went around all the edges of the stainless trim. Also butyl taped the door ledge below the door so the trim clamped down onto it (to keep water out). I clamped the carpet with the trim. I was a bit sad about early signs of rust in the footwell (hardly surprising with all the bloody water getting in) but treated it with KuRust and smothered everything with ACF-50 (I'm sure Zag will approve). Finished by stuffing more butyl into every nook and cranny. Wasn't sure whether to fill a big gap at the back end with PU foam but opted for...more butyl instead (figured it might be good to leave a "breather" hole just in case). Hope that makes sense. It's looks 90% pretty and 10% industrial but that's fine for me ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 244 ![]() ![]() ![]() |
Could we please have some pictures so we can see what we are missing!? 1990 Defender 110 200TDI Camper - now converted to Td5 power
Being incredibly selfish ![]() When I do the rear ones (after more butyl has arrived - ran out) I will photograph the whole process ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
