![]() | Home > Puma (Tdci) > Heavy Clutch PEdal |
hossegor Member Since: 05 Feb 2012 Location: Frankfurt Posts: 19 ![]() ![]() |
i notecid that the clutch pedal on my Defender is very stiff and hard to push down. Even compared to the other landys i have driven.
i would like to do the a clutch pedal mod, i have read that replacing the pedal/spring with one from the 300 tdi would help.(part nr ANR5311) has anyone done this mod? heres a thread for the td5 , i am just not sure if this also works for the puma..http://www.defender2.net/forum/topic6616.html |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
A company called redbooster do an additional servo kit and it makes a hell of a difference
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
raul Member Since: 11 Jul 2015 Location: Lima Peru Posts: 1 ![]() ![]() ![]() |
A friend changed 3/4 pump with a 5/8 pump and result is excelent
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
Thanks for your reply but as I don't understand could you please explain what that means.
Cheers Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
Master cylinder bore i think.
There is also a revised slave cylinder which makes it slightly lighter, but i'm not sure when it bacame standard fit on the production line. Mine with all the latest bits is certainly heavier than a modern car, but it's not worse than any other Defender i've driven. it could be that some of the pivots in the pedal box need a drop of oil? |
Could you get the type/brand of the modified pump? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3329 ![]() ![]() |
As far as l know The tdci already has the "lighter clutch pedal spring" fitted as standard.
All the tdci's l've driven have had a fairly light clutch, certainly better than my TD5 (before l fitted the spring mod) If your tdci has a heavy clutch l would think it's faulty/worn close to the limit. |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
I freed my 130 off by using much penetrating oil last week. It's come back all 2017 easy rather than 2012 sticky! 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
Any one got any more info if this is worth doing as mine is stiff as **** Stew |
No news? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
It doesn’t help being a short ass
Just googled red booster and found a great vid with it fitted to a td5 , I’ll lookin to it tomorrow
![]() ![]() Click image to enlarge |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
LOF Power Master & their pedal spring! HUGE difference!
I quite like the fact its a heavy clutch peddle
![]() Self confessed mileage hunter ![]() |
