Home > Puma (Tdci) > Heavy Clutch PEdal
hossegor
Germany
Heavy Clutch PEdal
i notecid that the clutch pedal on my Defender is very stiff and hard to push down. Even compared to the other landys i have driven.
i would like to do the a clutch pedal mod, i have read that replacing the pedal/spring with one from the 300 tdi would help.(part nr ANR5311)
has anyone done this mod?
heres a thread for the td5 , i am just not sure if this also works for the puma..http://www.defender2.net/forum/topic6616.html
Post #131183 14th Mar 2012 12:17am
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Had a test drive today in a 2013 110 USW XS and also found the clutch pedal really hard to depress. Is there a modified spring that can be fitted to this age of vehicle to make it easier to depress? If so, advice on how to do it would be appreciated. Or is it the same as a TD5 detailed elsewhere on this site. What part number is the replacement spring? Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #622982 9th May 2017 8:37pm
bear100
A company called redbooster do an additional servo kit and it makes a hell of a difference Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #622996 9th May 2017 9:16pm
raul
Ecuador 2013 Defender 110 Puma 2.2 CSW Barolo Black
A friend changed 3/4 pump with a 5/8 pump and result is excelent
Post #634929 1st Jul 2017 5:50pm
Sammyboy
Thanks for your reply but as I don't understand could you please explain what that means.
Cheers Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #635247 3rd Jul 2017 9:27am
zsd-puma
Master cylinder bore i think.
There is also a revised slave cylinder which makes it slightly lighter, but i'm not sure when it bacame standard fit on the production line.
Mine with all the latest bits is certainly heavier than a modern car, but it's not worse than any other Defender i've driven. it could be that some of the pivots in the pedal box need a drop of oil?
Post #635360 3rd Jul 2017 6:31pm
dgardel
Italy
Could you get the type/brand of the modified pump? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #636453 8th Jul 2017 11:08pm
lightning
As far as l know The tdci already has the "lighter clutch pedal spring" fitted as standard.
All the tdci's l've driven have had a fairly light clutch, certainly better than my TD5 (before l fitted the spring mod)
If your tdci has a heavy clutch l would think it's faulty/worn close to the limit.
Post #638813 21st Jul 2017 4:04pm
familymad
I freed my 130 off by using much penetrating oil last week. It's come back all 2017 easy rather than 2012 sticky! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #638869 21st Jul 2017 9:17pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Any one got any more info if this is worth doing as mine is stiff as ****
Stew
Post #840525 29th Jun 2020 7:33pm
dgardel
Italy
No news? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #840526 29th Jun 2020 7:39pm
stew 46
It doesn’t help being a short ass Laughing
Post #840529 29th Jun 2020 7:41pm
stew 46
Just googled red booster and found a great vid with it fitted to a td5 , I’ll lookin to it tomorrow Thumbs Up
Post #840531 29th Jun 2020 7:45pm
HardCharger
LOF Power Master & their pedal spring! HUGE difference!
Post #840585 30th Jun 2020 3:50am
shaggydog
I quite like the fact its a heavy clutch peddle Embarassed Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #841045 1st Jul 2020 4:10pm
