Home > Maintenance & Modifications > wiring up heated seats
Killer90
Site Sponsor
right just brought some new puma xs heated seats its a shame not to wire them up but i am not that bothered to buy all the loom etc etc so is there a easy way or wiring it to a switch all help appreciated thanks Thumbs Up
Post #118774 26th Jan 2012 9:40pm
BigRuss
From what I can recall the seats should only have a +ve and a -ve so just a simple switch and fused feed to the battery should do Thumbs Up Russell
2011MY 110 XS USW Black
Post #118779 26th Jan 2012 9:48pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
With the current draw you will need relays and wiring to suit, there are plenty of kits on eBay starting as little as 99p
http://www.ebay.co.uk/itm/Vw-Golf-Mk3-heat...500wt_1288
Jason.
Post #118785 26th Jan 2012 9:57pm
Killer90
Site Sponsor
cheers guys i was hoping it would be easy i think they are a waste of time personally Laughing i can never feel it in dads 110 but then i spose if i got it and got a space in the dash for it why not Thumbs Up
Post #118818 26th Jan 2012 11:41pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thats one part of the defender the good lady likes! Wink 2008 110 XS CSW Stornoway Grey
Post #118833 27th Jan 2012 6:36am
BigRuss
I must say these seats a good but the best heated sets I ever had we're in an old Volvo 440 i used to own. Russell
Post #118844 27th Jan 2012 8:39am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Looking at the official wiring diagram, LR dont use relays on the seats, just the two switches on the dash (TD5) which switch the + side of the circuit. The seats are locally earthed.
Post #118857 27th Jan 2012 9:54am
Killer90
Site Sponsor
cheers paul i also done a little research this morning and found the same so it looks pretty simple to do Thumbs Up
Post #118863 27th Jan 2012 10:24am
PaulMc
Have a look at -
http://www.defender2.net/forum/topic7679.html
http://www.defender2.net/forum/topic8713.html
http://forum.landrovernet.com/showthread.p...ost1609513
http://forums.lr4x4.com/index.php?showtopic=69458
. Paul.
Post #118870 27th Jan 2012 11:37am
Killer90
Site Sponsor
Thumbs Up will have read cheers
Post #118982 27th Jan 2012 6:18pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi Killer90 I have a complete wiring loom with switches,all you need is a fuse box live and a earth plus tap into you original loom for switches to come on with lights,I removed from a td5 XS loom.
the switches are for a tdci has they are different to a td5.
would accept £40.00 posted if any good?
thanks Ash
Post #119400 28th Jan 2012 10:48pm
K9F
On the Puma the supply is switched through the ignition via the 'Window lift relay' R143 which is protected by both the 100 Amp and 60Amp main links. The seats themselves are then protected by a 20 Amp fuse.
When the ignition is off the window lift relay switches the main live feed to the seats down to earth. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119455 29th Jan 2012 10:48am
Killer90
Site Sponsor
pm sent Thumbs Up
Post #119458 29th Jan 2012 11:07am
RRUK
Just adding to all the information already posted by PaulMc on this topic, he helped me with a kit to wire mine up, and I have put some info in the thread about My Defender.
http://www.defender2.net/forum/topic10705-180.html 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #164287 25th Aug 2012 9:24am
