![]() | Home > Maintenance & Modifications > wiring up heated seats |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
From what I can recall the seats should only have a +ve and a -ve so just a simple switch and fused feed to the battery should do
2011MY 110 XS USW Black |
| jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268
With the current draw you will need relays and wiring to suit, there are plenty of kits on eBay starting as little as 99p
http://www.ebay.co.uk/itm/Vw-Golf-Mk3-heat...500wt_1288 Jason. |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
cheers guys i was hoping it would be easy i think they are a waste of time personally
| Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122
Thats one part of the defender the good lady likes! |
I must say these seats a good but the best heated sets I ever had we're in an old Volvo 440 i used to own. Russell
| Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384
Looking at the official wiring diagram, LR dont use relays on the seats, just the two switches on the dash (TD5) which switch the + side of the circuit. The seats are locally earthed.
cheers paul i also done a little research this morning and found the same so it looks pretty simple to do
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
Have a look at - http://www.defender2.net/forum/topic7679.html http://www.defender2.net/forum/topic8713.html http://forum.landrovernet.com/showthread.p...ost1609513 http://forums.lr4x4.com/index.php?showtopic=69458 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287
Hi Killer90 I have a complete wiring loom with switches,all you need is a fuse box live and a earth plus tap into you original loom for switches to come on with lights,I removed from a td5 XS loom.
the switches are for a tdci has they are different to a td5. would accept £40.00 posted if any good? thanks Ash |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
On the Puma the supply is switched through the ignition via the 'Window lift relay' R143 which is protected by both the 100 Amp and 60Amp main links. The seats themselves are then protected by a 20 Amp fuse.
When the ignition is off the window lift relay switches the main live feed to the seats down to earth. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
pm sent
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
Just adding to all the information already posted by PaulMc on this topic, he helped me with a kit to wire mine up, and I have put some info in the thread about My Defender.
http://www.defender2.net/forum/topic10705-180.html 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
