![]() | Home > Puma (Tdci) > Magnetic Drain Plugs |
Are the drain plugs for the Sump, Gearbox and transfer box magnetic?
If not, does anyone know where you can purchase magnetic replacements? LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
http://www.magneticoildrainplugs.co.uk/
....and it's not a Grockle 'special' ![]() |
Thanks for the link Laurie. Unfortunately they have none listed under Land Rover and I don't know the thread size/shape required. More research needed.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
http://www.x-eng.co.uk/X-Plug.asp?MID=70
X-eng do plugs for diffs - I have had a couple for a while. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Found plenty of Diff Magnetic drain plugs - but it's the Sump/Gearbox and Transfer box plugs I'm looking for. Anyway, thanks for the link.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Would think transfer box and gear box would already have magnetic ones fitted Td5 do.
Andy |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Mine have magnetic plugs as standard
![]() 98 V8 Disco |
So the TDci has magnetic drain plugs on the Sump,Gearbox and Transfer box as standard?
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Mine doesn't. It has magnetic on the Transfer Box, but the gearbox wasn't magnetic.
I will probably replace it, but not until the Warranty's expired. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
So we seem to have conflicting advice. Does anyone know if the 2010MY Puma has any magnetic drain plugs on the engine.gear box/transfer box?
I changed all my oils in my 2011 Defender.
I wrote it up here: http://www.defender2.net/forum/topic8707.html The Gearbox DOES NOT have a magnetic drain the Transfer box DOES HAVE a magnetic drain plug ...assuming they are all the same ![]() |
So the conclusion so far is:
Transfer Box DOES have a magnetic Drain Plug Gear Box DOES NOT have a magnetic drain plug. Engine Sump ??? DOES NOT have a magnetic drain plug. So does anyone know if anyone can supply magnetic drain plugs for Gear Box and/or Engine Sump. I've only been able to find Diff drain plugs that are magnetic. ![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
On both the sump and gearbox drain plugs I glued 2 small magnets. They do the job. Just need to be careful while removing the plugs
![]() ............................................................. Earth first. Other planets later |
That's an excellent idea MK.
![]() ![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
