Home > Puma (Tdci) > Magnetic Drain Plugs
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Are the drain plugs for the Sump, Gearbox and transfer box magnetic?
If not, does anyone know where you can purchase magnetic replacements? LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #117522 22nd Jan 2012 4:18pm
Laurie
http://www.magneticoildrainplugs.co.uk/
....and it's not a Grockle 'special' Wink
Post #117526 22nd Jan 2012 5:30pm
WelshGas
Thanks for the link Laurie. Unfortunately they have none listed under Land Rover and I don't know the thread size/shape required. More research needed. Thumbs Up LANDYWATCH
Post #117530 22nd Jan 2012 5:58pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
http://www.x-eng.co.uk/X-Plug.asp?MID=70
X-eng do plugs for diffs - I have had a couple for a while.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #117532 22nd Jan 2012 6:06pm
WelshGas
Found plenty of Diff Magnetic drain plugs - but it's the Sump/Gearbox and Transfer box plugs I'm looking for. Anyway, thanks for the link. Thumbs Up LANDYWATCH
Post #117536 22nd Jan 2012 6:17pm
landy andy
Would think transfer box and gear box would already have magnetic ones fitted Td5 do.
Andy
Post #117537 22nd Jan 2012 6:20pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine have magnetic plugs as standard Thumbs Up 130 crew cab
98 V8 Disco
Post #117586 22nd Jan 2012 8:03pm
WelshGas
So the TDci has magnetic drain plugs on the Sump,Gearbox and Transfer box as standard? Question LANDYWATCH
Post #117691 23rd Jan 2012 12:57am
MartinK
Mine doesn't. It has magnetic on the Transfer Box, but the gearbox wasn't magnetic.
I will probably replace it, but not until the Warranty's expired. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #117714 23rd Jan 2012 9:51am
WelshGas
So we seem to have conflicting advice. Does anyone know if the 2010MY Puma has any magnetic drain plugs on the engine.gear box/transfer box? Bow down LANDYWATCH
Post #118242 24th Jan 2012 9:32pm
Zagato
Rossy may be able to confirm either way, he changes his oils every morning Very Happy Was told by the LR mechanic the gearbox does Neutral
Post #118244 24th Jan 2012 9:35pm
MartinK
I changed all my oils in my 2011 Defender.
I wrote it up here: http://www.defender2.net/forum/topic8707.html
The Gearbox DOES NOT have a magnetic drain
the Transfer box DOES HAVE a magnetic drain plug
...assuming they are all the same Confused Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #118319 25th Jan 2012 11:32am
WelshGas
So the conclusion so far is:
Transfer Box DOES have a magnetic Drain Plug
Gear Box DOES NOT have a magnetic drain plug.
Engine Sump ??? DOES NOT have a magnetic drain plug.
So does anyone know if anyone can supply magnetic drain plugs for Gear Box and/or Engine Sump. I've only been able to find Diff drain plugs that are magnetic. Big Cry Big Cry LANDYWATCH
Post #119179 28th Jan 2012 8:23am
MK
On both the sump and gearbox drain plugs I glued 2 small magnets. They do the job. Just need to be careful while removing the plugs Thumbs Up Puma 110" SW
Post #119231 28th Jan 2012 12:42pm
WelshGas
That's an excellent idea MK. Thumbs Up Thumbs Up Thumbs Up LANDYWATCH
Post #119269 28th Jan 2012 3:36pm
