Home > For Sale & Wanted > WANTED mk3 widde track disk brake sankey trailer
Page 2 of 2 <12
T1G UP
Ok Fitting a nato hitch high up but also interchangable with the standard tow bracket??
I can lose the towbar, didn't ask for it anyway!
I need t removeable nato hitch / drop plate set up i think.
Any off the shelf options?
UPDATE. found this item http://www.extreme4x4.co.uk/acatalog/copy_...WBARS.html
and
http://www.extreme4x4.co.uk/acatalog/QUICK...EIVER.html
and other suppliers?
Post #117293 21st Jan 2012 5:39pm
Yeah, the Dixon Bate adjustable tow bar as per the picture you posted earlier. Just fit each of your chosen hitches to separate sliders.
I'm pretty sure that the 2 inch square receivers aren't type-approved for post '98 vehicles, Darren
Post #117294 21st Jan 2012 5:45pm
T1G UP
don't have the adjustable one Big Cry i have the standard LR tow bar like this http://www.ebay.co.uk/itm/genuine-land-rov...500wt_1361
so i'd rather ditch the lot and start a fresh with a high up removeable one.
How would i find out about type approval? got a 1 tonne trailer so needs to be fit for purpose
Post #117296 21st Jan 2012 5:57pm
The Dixon Bate one is a complete set-up and replaces the standard tow bar. You then buy extra sliders for each tow hitch that you need.
Have a look HERE.
Only type-approved tow bars are legal to use on vehicles first registered from 1998 onwards. The 2 inch receiver hasn't, to the best of my knowledge, been type-approved and neither has the Southdown type ones that form part of a tank guard. Ones that have been type-approved should be marked and, I'd expect, advertised as such. Darren
Post #117300 21st Jan 2012 6:06pm
JSG
The receiver hitch isn't approved for post 2007 models. The best option is to use the Landrover adjustable tow bar and if you're going to buy a new one I'd go down that route.
The other option is to bolt a slider to your current tow bar so you can swop them easily.
Something like this.
 John
2011 Tdci 110 CSW XS
Post #117305 21st Jan 2012 6:14pm
T1G UP
can i just bolt the Nato hitch to the crosmember? it has threaded bolt holes. I can remove it then when not needed
Post #117306 21st Jan 2012 6:17pm
JSG
Yes you can - the holes are threaded and in the right place but I would use a towbar for a stronger solution. John
Post #117311 21st Jan 2012 6:27pm
T1G UP
the issue is a towbars to low, a adjustable towbars to low as the rapier trailer hitch is spot on for bolting to xmember?
Post #117313 21st Jan 2012 6:31pm
mikesmif
Hi all,
I too am looking for a disc braked Sankey. Any one know of anyone selling one? Thanks, Mike
Post #169606 20th Sep 2012 9:44pm
T1G UP
PM greeni, he knows of some
Post #169612 20th Sep 2012 10:10pm
mikesmif
Thanks very much and very prompt.
Post #169613 20th Sep 2012 10:11pm
Don't simply bolt a NATO pintle directly to the cross-member on a TD5 or Puma, the cross-member isn't strong enough and you risk bending it. There is a genuine reinforcing plate for the job and they crop up quite often online or on eBay.
However the best option is the DB slider arrangement as illustrated earlier in the thread, since this is stronger still.
Post #169616 20th Sep 2012 10:32pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
GREENI wrote:
Do you want the rolling chassis or complete trailer...a friend has lots, damaged bodied ones if you want chassis only?
Hi Greeni,
Sorry to dig up an old post but does your friend still have sankey chassis. Thanks
Shane
Post #270421 30th Sep 2013 3:00pm
Page 2 of 2 <12
