![]() | Home > For Sale & Wanted > WANTED mk3 widde track disk brake sankey trailer |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Ok Fitting a nato hitch high up but also interchangable with the standard tow bracket??
I can lose the towbar, didn't ask for it anyway! I need t removeable nato hitch / drop plate set up i think. Any off the shelf options? UPDATE. found this item http://www.extreme4x4.co.uk/acatalog/copy_...WBARS.html and http://www.extreme4x4.co.uk/acatalog/QUICK...EIVER.html and other suppliers? |
Yeah, the Dixon Bate adjustable tow bar as per the picture you posted earlier. Just fit each of your chosen hitches to separate sliders.
I'm pretty sure that the 2 inch square receivers aren't type-approved for post '98 vehicles, Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
don't have the adjustable one
![]() so i'd rather ditch the lot and start a fresh with a high up removeable one. How would i find out about type approval? got a 1 tonne trailer so needs to be fit for purpose |
The Dixon Bate one is a complete set-up and replaces the standard tow bar. You then buy extra sliders for each tow hitch that you need.
Have a look HERE. Only type-approved tow bars are legal to use on vehicles first registered from 1998 onwards. The 2 inch receiver hasn't, to the best of my knowledge, been type-approved and neither has the Southdown type ones that form part of a tank guard. Ones that have been type-approved should be marked and, I'd expect, advertised as such. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The receiver hitch isn't approved for post 2007 models. The best option is to use the Landrover adjustable tow bar and if you're going to buy a new one I'd go down that route.
The other option is to bolt a slider to your current tow bar so you can swop them easily. Something like this. ![]() John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
can i just bolt the Nato hitch to the crosmember? it has threaded bolt holes. I can remove it then when not needed
Yes you can - the holes are threaded and in the right place but I would use a towbar for a stronger solution. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
the issue is a towbars to low, a adjustable towbars to low as the rapier trailer hitch is spot on for bolting to xmember?
mikesmif Member Since: 20 Sep 2012 Location: Walsall Posts: 2 ![]() |
Hi all,
I too am looking for a disc braked Sankey. Any one know of anyone selling one? Thanks, Mike |
PM greeni, he knows of some
Thanks very much and very prompt.
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551 ![]() ![]() ![]() |
Hi Greeni, Sorry to dig up an old post but does your friend still have sankey chassis. Thanks Shane |
