![]() | Home > My Defender > should I go for a pair of JWS 8700's ? |
do you think 8700's would look ok on my 110 ?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
YES treat yourself for xmas i love mine
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
Go for it.
mao - i'm considering moving the sidelights into the spots by making a hole at the bottom of the lens, the wires are long enough just need to find a specialist to dril the lens, then using LED sidelight bulb either glue or mastic it into place. ![]() |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
That'll work or you could swap the spots for some with type of side bulb in? Looks like you've convinced yourself so get the money out ![]() ![]() 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
This is a Defender2.net exclusive! This is a sneak peek of our latest project car, which was only photographed yesterday.
![]() ALIVE is delighted to announce that we have been chosen as a premium distributor for Land Rover LED lighting products by JW Speaker and Mobile Centre. We have the very first 8700 LED Headlamps with built in sidelights, for use with the SVX grille set, which will be available from early January. Come and see them on our new 2012 Puma 90 demonstrator at Autosport International, from January 12th. |
Perfect timing ![]() ok, I'm sitting down: what's the damage ? |
Please give us a call so we can discuss this further. No need to be sat down, as you know we'll look after you. ![]() |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
That's awsome. I'd been thinking about this too and having the same front had come across the same issue. Putting LED sidelights into any hot lamp (spot or otherwise) simply does not work long term, as the LED's don't cope well with the extended temperatures they have to content with. I'd looked on the web and wondered if Speaker did one of these with an integral sidelight.
Pete |
Group buy?
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
![]() 2011MY 110 XS USW Black |
they are great lights
So say you bought a set of RHD lights and you went to a LHD country on holiday, how would you overcome the beam direction issue??
I'm not trying to put people off but trying see he this problem is solved before I sneak something else past the wife ![]() ![]() 2011MY 110 XS USW Black |
It might seem an obnoxious answer but why bother do our friends from the Euro zone do the same for us ?
Look at the LGV’s not one bothers with beam deflectors (Not sure if there is an answer BTW re the JW’s ) I drive/drove all over Europe and not once have I’ been stopped for light infringements might of had a few Paris peyage moments re Tacho infringements making the Friday night ferry but nothing 200 B&H didn’t sort (bring back those days ) ![]() Last edited by ken on 22nd Dec 2011 1:43pm. Edited 1 time in total |
