Home > My Defender > should I go for a pair of JWS 8700's ? |
worth a try! |
4th Jan 2012 11:11am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Not sure if its been said already but the D2 uses a high pressure pump for the washers and is relitivly cheap. I first saw it used apart from on the D2 on the Bowler Wildcat where they also used the D2 washer jets on a special mount to get the angle correct. I think it would fit well in the front bumper ofthe defender and it could also if needed be coupled with a small pcb containing a MCU that would activate them for a certian time when the normal screen washers are activated like on the New 2012 Evoque RRS etc etc. Pete |
8th Jan 2012 12:21pm |
