![]() | Home > Technical > sandblasted |
| LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241
I'm going toget my chassis sandblasted for my 90 rebuild and want some info for painting it.
Option 1 is to etch prime it and undercoat + paint it with 2k auto paint. Option 2 is epoxy prime and paint with 2k. Which would you think is better.Galvanising is not an option here. Puma 110 SW 90 V8 SOFT TOP |
| kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987
Stove enamel
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I'd go for a zinc rich primer such as Unidox followed by an enamel top coat such as Woco Supercote. Provides a very tough finish. Darren
They came to do a test and sprayed a type of liquid after (acid) and a week later with the chassis been outside,there is no sign of rust. Puma 110 SW 90 V8 SOFT TOP |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
blast it then quickly paint it with Tetrosyl chassis paint. no need for primer or etcher.
you mustnt wait long to paint it after its been blasted, try to do it same day. |
POR 15 is good stuff, but bear in mind that it's not UV stable so needs to be covered up if it's going to be a rolling chassis for any length of time. It's also not the best choice for the exposed rear crossmember. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
You can get POR-15 that is UV resistant |
(scuttles off to Google it)
Oh yes, so you can I still prefer a nice, heavy, zinc-rich primer though 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Epoxy primed the chassis today.Looks sweat,but took me 2 hours to spray as the little hidden cavities were trying to get the better of me.I won though. Puma 110 SW
90 V8 SOFT TOP |
