Home > Maintenance & Modifications > Defender hesitating / surging under load
LandyMarmy
 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi, New to the site and Martin gave me a few pointers to use it correctly, thank you Martin.
My 2011 90 2.4 has had a re map, a larger Allisport intercooler and 3" exhaust a few years ago. It's running great apart from it hesitates when put under load a couple of times then settles down until changing up a gear when it does it again. I've changed the MAF sensor, but no different. :blub: Any ideas, turbo sticking perhaps?
Any help would be appreciated. Thanks.
Post #998509 4th Jul 2023 10:22am
Check for DTCs, if none, replace the VCV.
Post #998517 4th Jul 2023 11:04am
LandyMarmy
Thanks for the quick reply. I'm OK with spanners, but no engine mechanic so could you please explain what CTC's are and what the VCV is. Thanks..
Post #998523 4th Jul 2023 11:19am
LandyMarmy
Read up on it, Diagnostic Trouble Code and Fuel Vapour Valve. I'll try those thanks..
Post #998524 4th Jul 2023 11:31am
Ianh
DTC = Diagnostic Trouble Code. You have an OBD2 port in the fuse box under the steering wheel. You connect a diagnostic tool to that port to read DTC’s . These codes are an alpha numeric format and each one points to a specific test that has not performed as it should and therefore a single DTC or combination of DTCs allows you to localise an issue with the engine, sensors, brakes etc.
Cheap ELM327 code readers coupled with a free phone app such as torque will allow you to read the codes, look them up on the internet or post on here and we can advise on what you issue probably is.
As Blackwolf states, the lack of any DTCs and the issue you have would point towards a VCV ( fuel volume control valve) issue, which is very common on the 2.4.
Post #998525 4th Jul 2023 11:44am
LandyMarmy
Thank you for that. I have a code reader knocking about somewhere, ill dig it out and check. No engine lights on at present, but something might come up. If the VCV is a common fault then I'll get my local to change it and report the findings. Cheers.
Post #998529 4th Jul 2023 11:59am
Ianh
If you are ok with spanner’s, and Allen keys then the VCV changeout s not technically difficult, just awkward due to restrictive access.
The key thing is to get a Genuine Denso VCV from a very reputable supplier as lots of fakes out there that just don’t work or fail very quickly.
See bell auto services site for instructions. Ps most don’t do a pump learn or pilot correction with diagnostics tools and all runs well after a few miles driving.
https://bellautoservices.co.uk/store/defen...our-valve/
Post #998540 4th Jul 2023 1:55pm
LandyMarmy
That's a good sight thanks and it seems easy enough to do. I tried to order one from Bell, but they are out of stock so I'll try and get a quality one elsewhere. Thanks for the advice and wish me luck. I'll let you know the result Thumbs Up
Post #998552 4th Jul 2023 3:08pm
