Home > Puma (Tdci) > hand brake light flashes!!1
s18mcn
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
my handbrake light on my dash flashes a lot ive changed the switch on the side of the handbrake thinking it was that but no it still does it!!!!!!! any suggestions???
Post #99752 13th Nov 2011 8:18pm
Check your brake fluid level. IIRC it's a dual purpose light. Darren
Post #99755 13th Nov 2011 8:26pm
s18mcn
iwill do,, when i say it flashes its normally when im coming to a stop//
Post #99756 13th Nov 2011 8:29pm
spudfan
Ireland
According to the handbook not only does this light indicate when your handbrake is engaged, it also indicates that your brakefluid needs topping up or you have a problem with the EBD (Electronic Brake Distribution system if fitted). So check your brake fluid level first of all. If that is o.k. it must be a fault with the EBD, which is a garage job to check. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #99757 13th Nov 2011 8:30pm
s18mcn
kool many thanks!!! what is ebd? is it a standard bit of kit? or an extra?
Post #99759 13th Nov 2011 8:33pm
spudfan
Ireland
No,it is not standard, as far as I know it comes with the traction control options package. I do not have it. 1982 88" 2.25 diesel
Post #99761 13th Nov 2011 8:36pm
s18mcn
i havent got traction control either? mine was a standard county spec
Post #99762 13th Nov 2011 8:37pm
spudfan
Ireland
In that case it must be an indicator that your brake fluid is low. That brake pads could be nearing the end of their life so get them checked. The fluid level will drop if the pads get very low. 1982 88" 2.25 diesel
Post #99763 13th Nov 2011 8:40pm
s18mcn
ahh it could be that as when it last had an mot it did come with an advisory on the pads!!!
Post #99764 13th Nov 2011 8:46pm
spudfan
Ireland
OPIE OILS give a listing of suitable brake fluid. Here is the link.
http://www.opieoils.co.uk/product-finder/c...der-2.aspx 1982 88" 2.25 diesel
Post #99766 13th Nov 2011 8:51pm
s18mcn
Many Thanks!!!!
Post #99767 13th Nov 2011 8:53pm
spudfan
Ireland
Very Happy Thumbs Up 1982 88" 2.25 diesel
Post #99769 13th Nov 2011 8:54pm
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
Embarassed 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #99772 13th Nov 2011 9:03pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
As spud says your pads may need changing Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99776 13th Nov 2011 9:23pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
It could also be the little cable that goes to the switch has rubbed through and is touching on a peice of metal it only need to short to make a connection mine did this a piece of tape and job done
Regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #99788 13th Nov 2011 10:00pm
