![]() | Home > Puma (Tdci) > hand brake light flashes!!1 |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
Check your brake fluid level. IIRC it's a dual purpose light. Darren
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 53 ![]() ![]() ![]() |
iwill do,, when i say it flashes its normally when im coming to a stop//
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4806 ![]() ![]() |
According to the handbook not only does this light indicate when your handbrake is engaged, it also indicates that your brakefluid needs topping up or you have a problem with the EBD (Electronic Brake Distribution system if fitted). So check your brake fluid level first of all. If that is o.k. it must be a fault with the EBD, which is a garage job to check. 1982 88" 2.25 diesel
kool many thanks!!! what is ebd? is it a standard bit of kit? or an extra?
No,it is not standard, as far as I know it comes with the traction control options package. I do not have it. 1982 88" 2.25 diesel
i havent got traction control either? mine was a standard county spec
In that case it must be an indicator that your brake fluid is low. That brake pads could be nearing the end of their life so get them checked. The fluid level will drop if the pads get very low. 1982 88" 2.25 diesel
ahh it could be that as when it last had an mot it did come with an advisory on the pads!!!
OPIE OILS give a listing of suitable brake fluid. Here is the link.
http://www.opieoils.co.uk/product-finder/c...der-2.aspx 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Many Thanks!!!!
![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Bill Member Since: 20 May 2011 Location: Wicklow Posts: 39 ![]() ![]() ![]() |
![]() BMW R1150R KXF250 Keep On Truckin |
As spud says your pads may need changing ![]() |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
It could also be the little cable that goes to the switch has rubbed through and is touching on a peice of metal it only need to short to make a connection mine did this a piece of tape and job done
Regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
