![]() | Home > Puma (Tdci) > Seized crossmember bolts |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2269 ![]() ![]() ![]() |
I just did as Blackwolf suggests - it worked fine š
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Iād try soaking them in something like plus gas for a few weeks if you arenāt in a mad panic, then tighten and loosen them back and forth. Youāll struggle if itās the captive full length bar to get the middle ones soaked. It normally doesnāt take too much heat to crack them free once youāve the bloody thing off. Iāve ended up taking the mounting bar off the crossmember swapping chassis as you canāt get them out.
Some wheel alignment places would have an induction heater. |
Iām yet to find something that my m18 mid torque wonāt shift, let alone what the bigger ones do. But as you said, Iād be very wary of using it on smaller torx fittings |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 ![]() ![]() |
Alas I have made some progress at last! A combination of soaking in Holts Rustola for a couple of weeks and some heat from the blowtorch attachment on my gas soldering iron!
4 down, 6 to go! ![]() Click image to enlarge Excuse the naff paint work around the new bolts, the guy who did some repairs previously didnāt take the old bolts and washers out before doing a repair and painted over them ![]() |
Looking good - glad you managed to remove them.
Ooh look at those hinge bolts ⦠š |
Got to tackle the 6 crossmember bolts under the back door first š
I do intend to replace the hinges with Optimill eventually, so thatās why I havenāt gone for the stainless bolts on those ones. At least the hinges āshouldā be easier to remove, as most of the nuts are protected inside the car. Side Note: Does anyone know the size of the washers that Land Rover used, because these new bolts are the right size to match OEM, but the washers are almost the same size as the bolt head, so ideally Iād be looking to match the washer to OEM size as well⦠unless there is no gain to doing so? (The newer ones do look cleaner in my opinion) |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
There is no gain in doing so
![]() ![]() Click image to enlarge More details of how I did mine can be found here: https://www.defender2.net/gallery/albums/u...Bolts3.jpg Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I have black rubber ones, not very clear in the pics. Maybe nylon would be better, in which case I can always revisit.
Ah, yeah I see them now. Rubber's ok in that it'll provide the isolation. They're sometimes not rigid enough to tighten against without bulging, but I guess you'd already have noticed that. Darren
Yeah, I have noticed so am now on the hunt for a nylon replacement.. I avoided them bulging by leaving the bolts slightly loose whilst it is parked up for a bit. I can always nip them up if I go out in it, or when I get some nylon washers sourced.
Edit: Nylon washers ordered so will be all sorted by the end of the weekend hopefully ![]() |
