Home > Puma (Tdci) > thunk/thunk from rear of 110
Page 1 of 3 123>
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi there,
I have a thud or 'thunk' from the rear of my 110 USW that has lsowly got worse over the last 6 months, and is now driving me mad.
It happens when going over bumps - Originally over large bumps, now even small ones.
It sounds like it's coming from around the rear (2nd row) seat area in my USW, on the drivers side, and makes the whole rear bodywork reverberate, not to mention I can feel the thunk through my drivers seat.
I've emptied out the rear of the car, the rear trim is all fixed down tightly, but it still does it. Tightened down all the bolts from inside the rear of the 110.
Any ideas - I'm stumped?
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #99454 11th Nov 2011 11:12pm
JWL
Spare wheel on rear door? My TD5 with the later door does give me a noise not dissimilar to your description. Everything is tight I think the weight of the spare is doing the noise or its the door moving in the seal. Now there's an excuse for a swing away carrier Rolling Eyes
Post #99468 12th Nov 2011 12:50am
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
I would say its the rear bushings, cheep to replace, makes a big difference. 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #99491 12th Nov 2011 11:39am
spudfan
Ireland
My Puma is about 1 month old with 1400 kms on it and I am getting the same noise. Can't be worn bushings. Have checked anti roll bar and there is no movement there so the bushings are fine. Same with the shocks. Only problem I have with it. The 2008 model I have never did this. It will no doubt turn out to be something simple. Spare whell on the door has no movement either. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #99506 12th Nov 2011 3:28pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
'A' frame ball joint bush not seated properly? Not costly to replace unit, believe Paddocks do a H/D version.
Post #99508 12th Nov 2011 3:38pm
spudfan
Ireland
Could be but it is a bit hard to check on your own. Probably head to the garage where I got it and get it up on a lift. 1982 88" 2.25 diesel
Post #99512 12th Nov 2011 3:56pm
spudfan
Ireland
Undo the nuts on the door mounted spare wheel. Tighten them gradually turnabout,i.e don't tighten one fully then go to the next etc.Give one a few turns, then do the next one a few turns. Seems to have worked for me. 1982 88" 2.25 diesel
Post #99558 12th Nov 2011 8:30pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
mines done it from new - 5 months old now - its on the warranty list among other things when it goess back in
Post #99793 13th Nov 2011 10:10pm
szracer
Cheers, all. About to try the spare wheel re-tightening 'trick'.
ONe thing I did notice, when grovelling around under the car, was that the fuel filter guard flap seemed quite loose, and was clonking a bit when wobbling it. I wedged a piece of rubber in it, and this seems to have removed a slight clonk but not the main one.
What I have noticed is that the clonk gets better when the car is hot.......any ideas?
2005 Ducati ST3
1954 Sunbeam S8
Post #99872 14th Nov 2011 2:38pm
spudfan
Ireland
Just back from some bumpy roads. The above stopped the smaller knocking noise. The remaining noise sounds as if there is a loose piece of wood sitting on the floor and this jumps and lands when a bump is crossed. Have checked the seat cage underneath and that is ok. Bound to be something simple but I just cannot find it. 1982 88" 2.25 diesel
Post #99898 14th Nov 2011 4:08pm
szracer
Exact same noise I have - As others have said, bound to be something simple... Evil or Very Mad
2005 Ducati ST3
1954 Sunbeam S8
Post #99911 14th Nov 2011 5:43pm
spudfan
Ireland
Sat in the back this evening while the Mrs.drove. Noise seemed to come from the area at the bottom of the trim around the rear windows. It is not the rear seats or fixtures. It is not the backdoor. It is not the floor.Have not removed rear window trim to check. Does anyone who has no rear window trim get this noise?Maybe Solihull skimped on trim fasteners. Will investigate further tomorrow. 1982 88" 2.25 diesel
Post #100000 14th Nov 2011 11:54pm
szracer
Well, assuming we have the same noise, I hate to tell you, but in my USW (so no rear windows), I've actually fixed the rear trim to the frame using screws, so that can't move. I did actually wonder today if it was the rear door being loose on its catch, but unable to check on my own.
2005 Ducati ST3
1954 Sunbeam S8
Post #100006 15th Nov 2011 12:12am
spudfan
Ireland
Thumbs Up Bang goes that theory! Rear door seems rock solid. Roll on the next theory. 1982 88" 2.25 diesel
Post #100009 15th Nov 2011 12:19am
JWL
I've allways had the feeling that the noise stems from the back door, as mentioned above the door loose on the catch. The weight of the spare enough to "rattle" the door in its fastened position. I've tried to get the kids to move the door and they can allmost replicate the noise. When I was waiting for a replacement back window I had taken the spare off for a couple of days and the noise wasn't noticable, so one day that is going to be my excuse for a swing away carrier Whistle
Post #100011 15th Nov 2011 12:23am
Page 1 of 3 123>
