Home > General & Technical (L663) > New to here.
Page 2 of 3 <123>
Clemmo
I agree with the above and think the D250 is a more than adequate power plant.
The stop start functionality is a dream
I would treat yourself to the deployable tow bar …I hate “detachable”
Sometime I deploy mine just because I can Big Cry
Clemmo Thumbs Up
Post #993672 22nd May 2023 6:00pm
Moo
Ukraine
Chris S wrote:
Hi, thanks for your comments, it’s the wife’s car and she has early starts, in the winter she likes a warm car all defrosted before getting into it. I couldn’t find the option for a fixed multi height Confused tow bar, that’s what we use now on the discovery.
Ah. I thought it was the ionisation thingy you were talking about. I have the climate thing on my app. Works a treat but thought it came standard. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #993688 22nd May 2023 7:08pm
Retroanaconda
Definitely get the proper fixed towbar, the detachable one is rubbish.
Post #993711 22nd May 2023 8:24pm
mf7480
Why do you say that? I was apprehensive about the detachable as we do a lot of very heavy towing and the fixed wasn’t available when we ordered, but we’ve had no hassle at all. It’s still got zero play in it after 2 years work.
Post #993717 22nd May 2023 9:36pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Re: IID Tool
Chris S wrote:
I have a IID Toll for the discovery, I take it I would have to invest in a new one for the defender.
Tanks in advance
Chris.
If your IIDTool is a BT (Gen 3) you will just need to do a change of vehicle with GAP Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #993719 22nd May 2023 9:45pm
Retroanaconda
Because the receiver rusts within a year or so, meaning the tow ball section won’t locate properly without a hammer. The replacement (under warranty) did the same in one winter, so I bought a fixed one instead.
Post #993726 23rd May 2023 4:44am
mf7480
Fair enough, not a problem I’d come across but I covered the receiver and socket in grease the first time I used it, and never took it off again.
Post #993736 23rd May 2023 7:02am
Chris S
Re: IID Tool
Hairy Dan wrote:
Tanks in advance
Chris.
I have a Gen 2, I believe I can do a trade in for a Gen 3 along with some ££
Post #993752 23rd May 2023 9:13am
lightning
An occasional spray with WD-40 or similar prevents this happening
Post #993762 23rd May 2023 11:28am
stevemfr
France
Re: IID Tool
Chris S wrote:
Hairy Dan wrote:
Tanks in advance
Chris.
Yes, just contact us. We will do a partial exchange. https://www.gap-diagnostic.com/shop/exchange/
Brakes on the D300 can be modified to fit 18's (smaller rear calipers). But unless you are towing a heavy un-braked trailer or towing through mountains regularly, I can't imagine that the D250's brakes won't suffice.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #993777 23rd May 2023 3:41pm
Chris S
Thanks for all the advice/ information, I have revisited my build and gone for a D250 with more toys and it still came out cheaper than the D300 I originally was looking at.
Post #993786 23rd May 2023 4:57pm
Retroanaconda
Sadly not, tried that as well as grease etc. but both the original and replacement are rusted. Too much road salt.
Post #993835 24th May 2023 9:16am
Chris S
What towbar would you recommend, I would prefer a multi height?
Post #993902 24th May 2023 4:50pm
Retroanaconda
The genuine one is probably the best option:
https://accessories.landrover.com/gb/en/la...-pre-23my/
I’ve got an aftermarket one which looks pretty good and is much cheaper, but obviously I’ll need to install it myself. Because I have an existing genuine towbar I can reuse the electrics from it and avoid the hassle of integrating an aftermarket harness into the vehicle systems, which is the main issue with non-LR towbars.
Post #993908 24th May 2023 6:01pm
lightning
Which part rusts exactly? l will keep an eye on it.
Post #993927 24th May 2023 8:30pm
Page 2 of 3 <123>
