Home > Puma (Tdci) > Towing socket and CTEK
GM_FFX
United States 1992 Defender 90 200 Tdi HT Rimini Red
Hi guys does anyone here use the towing socket with an adapter to maintain their battery thru a CTEK? My understanding is that the socket is always on but I plugged it and the CTEK doesn’t see the battery. Or maybe the battery was too low.
Post #993479 21st May 2023 12:16pm
geobloke
Which type of towing electric socket(s) do you have? European or US?
Post #993488 21st May 2023 1:36pm
GM_FFX
It's a euro 2.2 puma with a 7 pin socket , the CTEK was 13 pin so I had to add an adapter to go from 13 to 7
Post #993491 21st May 2023 1:44pm
Martin
Site Admin
A single 7 pin socket doesn't have a battery connection.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993494 21st May 2023 1:51pm
GM_FFX
thank you, so the 7 pin doesn't carry power? This is the CTEK adapter I mentioned. Is the cigarette socket an alternative and stays on after key is removed?
edit: wrong adapter posted
Post #993495 21st May 2023 1:58pm
Martin
Site Admin
The photo you uploaded is the tow socket adapter (copy of mine, but anyway) but it requires the additional 7 pin (12S) socket with the extra wiring connections.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993496 21st May 2023 1:59pm
GM_FFX
Thanks Martin, I uploaded the proper adapter, I mistakenly bought a 13 pin, then realized I have a 7 pin as you can see here and so I bought a 13 to 7 adapter. So you're saying that the tow socket doesn't carry any power to the battery and this can't be used? In my other cars I use the cigarette socket because it's always on, I wonder if in the 2.2 puma is always on as well.
Post #993497 21st May 2023 2:06pm
Martin
Site Admin
That 7 pin socket is the 12N which only has lighting and no power (permanent or switched).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993498 21st May 2023 2:09pm
GM_FFX
So it's a no go... thanks Martin. In the manual I see a 13 pins, it must have been an option?
Post #993501 21st May 2023 2:14pm
Martin
Site Admin
There is indeed a 13 pin option (all tow electrics are accessories rather than factory fit) - I have it on my 2.2 Puma.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993503 21st May 2023 2:28pm
GM_FFX
Do you know if the cigarette socket is always on in a 2.2 TDCi and can be used to maintain the battery?
Post #993628 22nd May 2023 3:16pm
Martin
Site Admin
No, it comes on in the AUX key position (position 1)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993629 22nd May 2023 3:18pm
GM_FFX
arghhh! is that modifiable via OBD/computer like more modern cars or it's fixed?
Post #993630 22nd May 2023 3:19pm
Fixed, but you could rejig it to have a permanent live feed easily enough.
Post #993647 22nd May 2023 4:25pm
GM_FFX
Thank you guys, and wow I didn't know it was Martin that made those connectors, too bad I don't have that option, it would have been so helpful.
At this point the easiest way is to use the CTEK connector to the battery and have the pigtail come out of the seat, wondering how other users have done it. I was trying to avoid drilling holes.
Post #993658 22nd May 2023 5:21pm
