Home > In Car Electronics > Reversing Camera Positioning.
Page 2 of 2 <12
Swine&Small
Now I have learned something, thanks for that. Bet it was pricey
B 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #612982 29th Mar 2017 12:30am
Stacey007
TJ101
LOL,, Need to adjust the viewing setting Stacey, to get the correct side Smile
But thats just the same reason i have mine on the plinth, with a manual override switch, to check view at anytime
___________
I've no idea why the image is 'flipped' and no settings to un flip it (can anyone help)
It still works ace as I can see the back where the step and towbar is so can back up mighty close to anything behind... Thumbs Up
Post #613005 29th Mar 2017 8:36am
humby
United Kingdom 2015 Defender 110 Puma 2.2 SW Indus Silver
Would it be possible to get some updated viewing angles.
Will be installing a reverse camera shortly.
I am interested if possible picture of view;
1. Above rear washer jet
2. Below rear number light
3. Alternative mouting view for reverse parking visability
Camera Video Frame rate: 720P@30FPS, Lens Viewing Angle: 150 Degrees
https://www.myatoto.com/index/productDetai...country=GB
Post #987219 29th Mar 2023 12:47pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Re: Reversing Camera Positioning.
Woodruffsdad wrote:
I've just invested in an Americam Reversing Camera Kit ref. K21 (GRC002) for my 2005 Defender 110 Td5 Station Wagon and it looks very good. It's the one with the bulkier camera ref. C2.
My questions are:
1) Where is the best position to fix the camera?
2) Where is the best place to fix the monitor?
As far as cameras go if you mount it on magnets you can put it exactly where you want when reversing a trailer. It is then simple to change the view when you need to. Obviously not great if you want to stick it to the ali body though !
Post #987303 30th Mar 2023 8:37am
humby
Thanks for the suggestion and pic
Post #987408 30th Mar 2023 11:32pm
dainger
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I have found top of the rear door to be best as doesn’t’ get muddy. But it still needs a cloth run over it every now and again.
Post #990595 27th Apr 2023 6:21pm
humby
Thanks, I did end up with under the number plate LED light. I didnt want to add another whole to the tub.
Post #991843 8th May 2023 3:12pm
Furball
I stuck a small camera under the number/license plate light. Easy to drill the plastic, and run the cables inside.
I mounted a small screen above the rear mirror. I purchased a a door push (Rectangular piece of aluminium), cut it to length, bent it to the contour of the roof, painted it, and fitted it between the mirror and the interior light. Painted it black as the roof lining was black. Done;t have a photo of this - sorry.
Then fitted a switch in the cup holder, in the cubby box.
Since this, I have another Defender and it came with double din and camera fitted inside the rear cross member.
Post #992989 17th May 2023 3:58pm
humby
Yup i copied and went for that same approach. I did want to create a new holes in the tub.
The head unit i am using allows me to adjust the assisted parking markers so i can accomodate based on mounted viewing angle.
[/img]
Post #1000531 17th Jul 2023 2:55pm
Eduardo
I located the camera inside of the rear cross member hole. It's a well-protected spot and easy to wire.
Cheers Eduardo
Post #1000578 17th Jul 2023 6:32pm
humby
Ahh ok i am relocating the electrics for the tow there. Nice bracket here
Post #1000582 17th Jul 2023 7:00pm
Page 2 of 2 <12
