![]() | Home > In Car Electronics > Reversing Camera Positioning. |
| Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223
Now I have learned something, thanks for that. Bet it was pricey
B 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
| humby Member Since: 19 Aug 2022 Location: South Posts: 27
Would it be possible to get some updated viewing angles.
Will be installing a reverse camera shortly. I am interested if possible picture of view; 1. Above rear washer jet 2. Below rear number light 3. Alternative mouting view for reverse parking visability Camera Video Frame rate: 720P@30FPS, Lens Viewing Angle: 150 Degrees https://www.myatoto.com/index/productDetai...country=GB |
| chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 413
As far as cameras go if you mount it on magnets you can put it exactly where you want when reversing a trailer. It is then simple to change the view when you need to. Obviously not great if you want to stick it to the ali body though ! Click image to enlarge |
Thanks for the suggestion and pic
| dainger Member Since: 08 Feb 2022 Location: Harpenden Posts: 69
I have found top of the rear door to be best as doesn’t’ get muddy. But it still needs a cloth run over it every now and again.
Thanks, I did end up with under the number plate LED light. I didnt want to add another whole to the tub.
| Furball Member Since: 31 Jan 2016 Location: Wiltshire Posts: 42
I stuck a small camera under the number/license plate light. Easy to drill the plastic, and run the cables inside.
I mounted a small screen above the rear mirror. I purchased a a door push (Rectangular piece of aluminium), cut it to length, bent it to the contour of the roof, painted it, and fitted it between the mirror and the interior light. Painted it black as the roof lining was black. Done;t have a photo of this - sorry. Then fitted a switch in the cup holder, in the cubby box. Since this, I have another Defender and it came with double din and camera fitted inside the rear cross member. |
Yup i copied and went for that same approach. I did want to create a new holes in the tub.
Click image to enlarge The head unit i am using allows me to adjust the assisted parking markers so i can accomodate based on mounted viewing angle. [/img] |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111
I located the camera inside of the rear cross member hole. It's a well-protected spot and easy to wire.
Click image to enlarge Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
Ahh ok i am relocating the electrics for the tow there. Nice bracket here
