![]() | Home > For Sale & Wanted > [Wanted] Defender 110 (non runner?) or M57 Conversion |
| Lewysj Member Since: 21 Jan 2023 Location: Pembrokeshire Posts: 31
Would you be interested in a td5 90 pick?
Apologies, just seen “must have 5 doors”
| Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415
Bump
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Mine will be up on the market soon, need to give it a good clean and it's going in for a crank oil seal leak next week.
Td5 110 on a galvanised (was new) military HD armoured chassis. built as a 2005 spec Td5 but on a 1992 "J" logbook, might put some people off. Paintwork is starting to bubble in places now (eventhough it had a bare metal paint job in 2010 when I built it) Click image to enlarge Click image to enlarge |
Winch and numberplate won't be included mind.
Annoyingly I actually need one newer than a 94 L plate for my private plate.
Looks and sounds a cracking vehicle though! |
Bump - complete change of criteria, which has been updated in the opening post...
Basically 110, min 4 doors, Puma or M57 engine (runner or non runner), budget £20k ish |
| C&M Member Since: 28 Aug 2020 Location: Hampshire Posts: 185
Pity your budget is £10k short or you could have my 64 plate 110 - which is in cracking condition BTW
Click image to enlarge Defender D250 HSE Dender 110 XS - sadly gone VW Polo VW Caravelle - Gen 6 |
| AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1373
That 110 is lovely
| 130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
I have a 110 Station Wagon rolling chassis ready for a heart transplant!
Chassis is galvanised and then finished with epoxy two coat paint. Bulkhead is also galvanised, primed and painted keswick green. Axles tubes have been stripped and again painted with epoxy two coat paint. New turrets, shocks and springs. R380 gearbox. Steering column and box Main wiring loom Some headlining Boxes of other bits! Some bodywork (seatbox, rear body, floor plate, one B pillar, rear door) but you would need to source most of it. Have the military release papers to allow it to be registered as a 2004 '54' plate. Looking for around £4k for the whole lot. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
Looks a lovely Defender, just not quite within price range at this moment in time I'm afraid |
Thanks for taking the time to reply 130dreamer. Unfortunately it's a bit too much of project for me at the moment, as tempting as it is. |
| All times are GMT |
