Home > Puma (Tdci) > 2011 Landrover 2.4 diesel TDCi not starting
Page 2 of 3 <123>
Siwynne
Unplug fuel rail pressure sensor and try starting it.
Post #992423 12th May 2023 8:08pm
sdev
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Keswick Green
Thanks, that seems to be about the only sensor we've not yet changed. Would that failing give us P1293-00 and P1294 fault codes?
I'll try it on Monday morning. I'm assuming that when it is unplugged it sets the ECU to a kind of base running condition?
Post #992501 13th May 2023 8:11pm
Siwynne
It sounds like a short somewhere. Get the cover off and follow the loom back from the injectors. If you lay a duratorque loom out the injector connectors are almost the furthest from the ecu from memory there are two two the alt one to maf one to turbo one to exhaust and one to air con everything else is behind the injectors. Clean all contacts in connectors with contact cleaner same for glow plug relay on bulkhead and check the earth nut on the bulkhead between the ecu and the heater blower.
Post #992508 13th May 2023 8:53pm
Siwynne
Any luck? Have you checked the inertia switch is not triggered or faulty?
Post #992914 16th May 2023 11:28pm
There isn't an inertial switch on a 2.4 since it only has a mechanical fuel pump.
Post #992932 17th May 2023 8:44am
Siwynne
You are correct. My bad.
Can’t be much stopping this one starting. I’m intrigued to find out what the cause is
Post #992954 17th May 2023 12:49pm
What fuel rail pressures are you getting while cranking?
If is it cranking but not starting the most likely reason is that no fuel is being injected, in which case either there is fuel rail pressure but the injectors are not firing (i.e., electrical/electronic issue), or the injectors are firing but there is no fuel pressure hence no injection.
There are some other, more complex, issues which could be happening, but start with the simple things.
Post #992956 17th May 2023 1:17pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
4. Cigüeñal LR004396 Is it placed with the corresponding light against the flywheel?
Post #992985 17th May 2023 3:31pm
sdev
Thanks all for the comments
Siwynne: OK, we tried unplugging the fuel pressure sensor - NO CHANGE
MK: On PCM - is there a way that you can switch the IMMO off inside? Our diagnostic experts couldn't see how to do that.
Siwynne: today we checked all the wires, cleaned off some 'silicone' that was one some terminals; we checked and the wires seems Ok to us
blackwolf: when cranking we were getting 38125 kPa; but when we open an injector pipe there seems very low pressure. We disconnected the wires to the back of the fuel pump; no difference on pressure readings; we unplugged the wires from the fuel pressure sensor, still showing 38125 kPa when cranking.
But we do seem to have very little fuel at the injector pipes; it kind of bubbles out but no 'squirting' or 'spraying' so think we are not getting enough fuel to the injectors.
Fernando: I can not say if the replacement crankshaft sensor was placed with the corresponding light. I assume it was as the garage have experience in changing them. If it wasn't done properly would that lead to the issues we are seeing?
Summary
We are running out of ideas and patience; we still have some suspicion that the immobiliser (which has been checked/programmed and synchronised) is stopping fuel getting into the engine - i.e. it still hasn't sent the right information to the ECM/ECU to permit the engine to start. We know the engine itself works - we used a low level of ether and fired her up. It ran well.........but it wasn't enough to enable it to run on diesel...........
We plan to replace the fuel pressure rail sensor; we plan to remove the immobiliser/ECU/speedo and refit ones from a donor vehicle.
So frustrating!! Neutral DOES ANYONE KNOW OF A MAGICIAN ON LANDROVERS THAT LIVES IN THE DERBY AREA AND COULD COME OUT TO FIX IT? We'd pay of course as we are running out of options and it's a shame because the car is really something we want to keep and use for our safari plans. Smile
Post #993008 17th May 2023 5:25pm
Fernando
If the gap between the cpk and the flywheel is not respected, it will not work, I think it is 2 mm.
Post #993027 17th May 2023 7:19pm
Ianh
Re expert help. Talk to porny on here , Ian at IRB , also a site sponsor https://irbdevelopments.com/ , he is about an hour away and really knows his way around classic defenders.
Post #993052 17th May 2023 10:22pm
sdev
Thanks Ian H and Ciguenal
I have to assume that the mechanics that fitted the crankshaft sensor calibrated it to 2mm and set it correctly. Just to confirm, if this wasn't correct would we see a code on the ECM output or would it lead to the issues we have seen on fuel pressure for example?
Next step is we plan to replace the fuel pressure rail sensor; we plan to remove the immobiliser/ECU/speedo and refit ones from a donor vehicle.
I will also contact IRB to see if he has a torch to shine into the dark spaces and places on this vehicle!!
Post #993143 18th May 2023 2:38pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
I'm no expert but 38125 kPa is 381.25 bar of pressure that seems very high, it's not a nice round high number that sometimes instrument companies build in to show an obvious fault? Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #993155 18th May 2023 4:19pm
How were you measuring the FRP?
Post #993163 18th May 2023 5:28pm
sdev
The fuel pressure was measured on the OBC via our diagnostics man.
We will change the sensor to see what happens.
Post #993177 18th May 2023 6:28pm
Page 2 of 3 <123>
