![]() | Home > Technical > 300tdi bent push rod |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 368 ![]() ![]() ![]() |
Snapped timing belt.
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 265 ![]() ![]() ![]() |
Yes that’s what I thought that first but it was only one push rod and when engine running all other valves were moving fine. It’s a bit of a mystery.
Stripped the head off it this week and the garage reported gasket is fine and no valve to piston contact. Head and block look good. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
That is good news from the garage
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Bad injector leaking
Thank you for the suggestions..... By way of an update... the head went off for a service and valves on N0.3 cylinder were showing some witness marks against the guides and most likely sticking.
New pushrods fitted and new guides and all valves cleaned and ground. Back together and running nicely again so fingers crossed that has it sorted. |
