Home > Technical > Safety Devices Roll Cage
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Has anyone ever fitted a full external cage. If so on the rear crossmember mounts is the mount supposed to be shimmed to sit on the top of the crossmember??? Thanks in advance for any help
Post #991447 4th May 2023 1:43pm
bodstruck
On my 110 external cage the chassis bracket fitted to the inside of the crossmember. The top of that was shimmed to remove any gaps to the part that fits inside.
Pretty sure I have some pics if you need them.
Post #991462 4th May 2023 3:12pm
Def2 member Bankz5152 had one fitted to his TD5 110 and there is some info in this thread. He also did a good write up on a different and rather down-market forum, and I just I happen to have it book-marked since it was an excellent write-up. I don't know if the thread above or the other forum's thread answers your questions, but here is a link to the other place:
https://www.landyzone.co.uk/land-rover/ban...68/page-38
Knowing the fit and finish of classic Defenders I would think it inevitable that a fair amount of shimming and other jiggery-pokery is needed to get a good fit.
Unfortunately Bankz5152 later managed to bend his cage to a spectacular and shocking degree, and it provides a sobering example of why SD cages are good things to have. The picture below is taken from a post he made in a thread on this (Def2) forum:
Post #991466 4th May 2023 3:30pm
geobloke
~Everytime I see Bankz' DCPU in that state I shed a tear Big Cry But it underlines why I have a full SD cage fitted to Miffy.
Post #991468 4th May 2023 4:14pm
Sicastle71
This is the part I am talking about. Sits on rear chassis x member and goes to the top bottom of the tub. Not sure if the intent is to sit the top of the tube and right angle directly on the x member using the shims as one side would use up all the shims wondering if anybody could have a look cheers Simon
Post #991565 5th May 2023 11:02am
bankz5152
Ill dig out some photos from my fit. From memory i loosely bolted into the xmember then drilled to tops. Think there where a couple packers but mostly pulled in with a buzz gun - remember cages are meant to be installed under tension which is what helps create the brace strength.
Those where a pig to install! You need 2 people.
Landyzone downmarket? Never Laughing Instagram @defender_ventures
Empire Tuning - Agent
Post #991571 5th May 2023 11:56am
Sicastle71
Ok cheers and thanks for the help
Post #991573 5th May 2023 12:22pm
bodstruck
It's all coming back to me now Smile
No shims on the top of the crossmember. But yes to shims at the top to ensure there are no gaps between the tops and the tub. If you zoom in you can just see the single shim I had to use at the top.
Post #991578 5th May 2023 12:59pm
kenzle8a
Post #991580 5th May 2023 2:27pm
Sicastle71
Thanks for that bods so at the bottom where the bolts are for thro the x member does the top sit on the x member or slightly above
Post #991583 5th May 2023 3:23pm
bodstruck
Mine was slightly above. How much is dictated by the positioning of all the other gubbins. The crossmember bolts were the last ones I tightened. Nip everything else up to et it all lined up, tighten the crossmember bolts then tighten the rest to keep a bit of tension in the whole thing.
It is all in the instructions but don't forget the spacers inside the crossmember. Mine were quite tricky to get in.
Good luck Thumbs Up
Post #991584 5th May 2023 3:41pm
bodstruck
You can just see it at the bottom of this pic. I used some plastic window spacers to keep it up temporarily while I got it all bolted together. Probably sits about 5-8mm above.
Post #991585 5th May 2023 3:45pm
Sicastle71
Ok thanks for that yes the spacers do not even fit in they are a size in size fit in mine may shave a bit of them in the mill and then get them re powder coated as the chassis is a galvanised chassis and I don’t want to force them in. Thanks for the help
Post #991588 5th May 2023 4:51pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Rather than start a new thread, after trawling through the Def2 archives, I thought I would resurrect the most recent one.
Has anyone fitted the Safety Devices RBL138 7SSS to a Puma 90 HT?
http://www.safetydevices.com/expedition/pr.../276/1797/
If so, can you tell me where the internal hoop sits in relation to the seats?
Being tall, my backrest is reclined and there aren’t many great photos of the internal hoop in a HT but it would appear that it is behind the seat box and I may not find clearance an issue (have XS LR Premium seats fitted, so no shoulder wings to worry about)
Post #997312 23rd Jun 2023 9:46pm
bodstruck
Not sure about a 90 but if it sites behind the seatbox then it may be the same as my 110.
Post #997317 23rd Jun 2023 10:07pm
