![]() | Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2946 ![]() ![]() |
I honestly couldn’t tell the difference. The biggest improvement came when I let some pressure out of the tyres! Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 347 ![]() ![]() ![]() |
I see, so the springs are more than likely the biggest factor? I currently Have bilsteins on but cheap-o springs and I can hear my bones shattering with every minute pebble on the road
![]() ![]() My Instagram |
So took on the task of opening up the wing top today since the headlights are out. Rather than guess work I printed a profile to tape on and dremel to. Then just a vinyl surround to tidy it up. Just need to make a small plate to deflect a rush of water if I am washing it.
![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7926 ![]() ![]() ![]() |
Rather you than me! 😬 Nice work!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
mrfirepro Member Since: 07 Nov 2020 Location: kent Posts: 233 ![]() ![]() ![]() |
looks really good
Thanks Paul, Also managed to get a pair of the last Nolden Chrome Gen 1's which more or less completes the front after the winch is set.
Collected the replacement Trophy / Bowler Sills. Cut and folded from 3mm 304 SS. Will get these powder coated a satin black.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 876 ![]() ![]() ![]() |
Those sills look great Andy! Any chance of a production run or drawing for them? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
Don’t see why not, I am going to have a set of brackets made and then I could supply the full kit. Andy
Great! Keep me posted please Andy. I'm sure you get asked this a lot but... what sort of MPG are you seeing from the LS3? 1985 127 V8 Build Thread
Thanks Clayton,
As I patiently wait for my slot with Ged in the workshop to fit the cage i am just getting on with the easy stuff. Have a trophy rear badge due to be machined, powder coated and linished this week ![]() Click image to enlarge And I am still drawing up the graphics ![]() ![]() Click image to enlarge Bit more tidying up in here too ![]() Click image to enlarge Other than the light bar and works wheels i am pretty much there Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Andy I have heard good things about Eagle coatings from the motorbike boys over here for coating bolts and fixings, just outside mallusk. I’m going to take a load up to them myself for a 90 I’m going to start building and give them a go.
Thanks for contact ^^^
I gave these guys a try for the re door bolts, arrived next day. Still undecided if i will do all the hinges, black bolts kinda jump out against the white but I definitely need to change the cage bolts out. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
1mm cutter doing the job on the rear badge.
![]() ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
