Home > My Defender > Fuji 110 LS3 build
Page 51 of 65 <123 ... 505152 ... 636465>
mcma1
LJMARSDEN wrote:
Out of curiosity, why have you gone bilstein instead of Fox 2.0's? I could be wrong but you had the Fox set up a little while back? Would ike to know your thoughts.
I honestly couldn’t tell the difference. The biggest improvement came when I let some pressure out of the tyres! Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #989060 15th Apr 2023 3:20pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
I see, so the springs are more than likely the biggest factor? I currently Have bilsteins on but cheap-o springs and I can hear my bones shattering with every minute pebble on the road Big Cry Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #989091 15th Apr 2023 11:56pm
mcma1
So took on the task of opening up the wing top today since the headlights are out. Rather than guess work I printed a profile to tape on and dremel to. Then just a vinyl surround to tidy it up. Just need to make a small plate to deflect a rush of water if I am washing it.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #990276 25th Apr 2023 12:43pm
JOW240725
Rather you than me! 😬 Nice work! Thumbs Up James
Instagram @suffolk_rovers
Post #990278 25th Apr 2023 1:10pm
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
looks really good Thumbs Up
Post #990279 25th Apr 2023 1:13pm
mcma1
Thanks Paul, Also managed to get a pair of the last Nolden Chrome Gen 1's which more or less completes the front after the winch is set.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #990322 25th Apr 2023 7:21pm
mcma1
Collected the replacement Trophy / Bowler Sills. Cut and folded from 3mm 304 SS. Will get these powder coated a satin black.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #990439 26th Apr 2023 4:11pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Those sills look great Andy! Any chance of a production run or drawing for them? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #990465 26th Apr 2023 9:12pm
mcma1
Don’t see why not, I am going to have a set of brackets made and then I could supply the full kit. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #990480 27th Apr 2023 3:04am
Shroppy
Great! Keep me posted please Andy. I'm sure you get asked this a lot but... what sort of MPG are you seeing from the LS3? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #990891 30th Apr 2023 3:26pm
L110CDL
Very much liking the way you've gone with this project Andy, the detail is second to none as usual Bow down Clayton.
Keeper.
Post #993054 17th May 2023 10:29pm
mcma1
Thanks Clayton,
As I patiently wait for my slot with Ged in the workshop to fit the cage i am just getting on with the easy stuff.
Have a trophy rear badge due to be machined, powder coated and linished this week
And I am still drawing up the graphics Big Cry
Bit more tidying up in here too
Other than the light bar and works wheels i am pretty much there Andy
2014 Corris 110 SW
LS3 V8 build...
Post #993077 18th May 2023 6:56am
NickMc
Andy I have heard good things about Eagle coatings from the motorbike boys over here for coating bolts and fixings, just outside mallusk. I’m going to take a load up to them myself for a 90 I’m going to start building and give them a go.
Post #993517 21st May 2023 4:19pm
mcma1
Thanks for contact ^^^
I gave these guys a try for the re door bolts, arrived next day. Still undecided if i will do all the hinges, black bolts kinda jump out against the white but I definitely need to change the cage bolts out.
rustandoil wrote:
Have a look here
https://www.carbolts.co.uk/?gclid=CjwKCAjw...HcQAvD_BwE
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #993590 22nd May 2023 10:18am
mcma1
1mm cutter doing the job on the rear badge. Thumbs Up
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #994076 26th May 2023 7:48am
