![]() | Home > Td5 > Oil cooler |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Hello. What oil cooler are you referring to on the TD5 and eBay?
| Jim88er Member Since: 12 Jan 2022 Location: East Sussex Posts: 11
Yeah on the Td5 just below the turbo. I’m referring to the £40 ones on eBay as opposed to the £120 Brit part or £188 on paddocks spares for example
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1657
well i wouldn't risk my engine on cheap copy parts and not britpart either for that bit....any branded one would work for sure
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Bearing in mind Britpart's legendary reputation for quality, I'm staggered you'd even consider a component one-third the price of the Britpart one. I imagine you'd get what you paid for.
| ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105
I am 5000 km so far on a cheap aliexpress oil cooler, I have another one on stock just in case. I will like to buy the casing since I have seen it corroded on other TD5s EDIT: It has the same Weight (471gr) as the original (469gr) one that was fitted. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
