![]() | Home > My Defender > Fuji 110 LS3 build |
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
Need some help please. No one appears to do a black SS bolt kit for the exterior. Any suggestions of a company I could use to spec what I need? Could my existing SS bolts be coated? On the Trophy all the doors have black bolts but I may just do the rear and cross member few under the rear door as it’s all getting painted black. Cheers Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747
Have you looked at getting a standard set Xylan coated? Turns them black and gives corrosion protection.
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868
Have a look here
https://www.carbolts.co.uk/?gclid=CjwKCAjw...HcQAvD_BwE |
Perfect thanks Andy
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
Accu will stock most things in black stainless or they will make them to order.
https://www.accu.co.uk/5-precision-screws |
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 842
I had a set from nakagennagga (the guys in Germany) they were on back order so I added my name to the list, they have some issues, but I am told its due to the process of how they are coated, some have the middle of the screw still silver etc, but they worked for what I needed, though not cheep. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Making progress, mainly taking bits off
Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
SPRING20 discount code on JLR Classic parts has helped.
Test fit of the winch, 4 bumper holes are a little off which is annoying but easy enough the fix.
Click image to enlarge Managed to get the handles apart for black anodising ( small M3 bolt with loctite was the potential issue ) Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Bought the closest registration I could to the original on the Works Camel Trophy....
Andy
| shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 548
Andy,
Have you looked at Performance Coatings in Cork for your bolts Shane |
Thanks Shane,
Sills have proved tricky to get as obviously Bowler wont sell them so I bought a set standard from them, fitted the mounting brackets and a quick scan will let me create the T2 design. They are a single piece cut and folded with 2 end caps, and I can then retain the jacking points. I will also print a bracket to hold the battery conditioner that clips onto the new sill under the door. Click image to enlarge Click image to enlarge And then wrapped the top of the shocks as the visible yellow was annoying me Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 350
Out of curiosity, why have you gone bilstein instead of Fox 2.0's? I could be wrong but you had the Fox set up a little while back? Would ike to know your thoughts. 4.0 V8 Defender 90
My Instagram |
There’s always the black bilsteins if you fancy an upgrade.
https://www.4x4proyect.com/parts/bilstein-...ock-kit/en |
