![]() | Home > Puma (Tdci) > Heater always hot!! |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Open the bonnet and check the heater cables on the heat matrix. It’s on the passenger side of the bulkhead. Mine needed some wd40 and worked fine after.
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1251 ![]() ![]() |
Mine did just the same, I worked out it was not shutting off (moving to the right as you look at it from the open bonnet). Only by a tiny movement but it just kept the heater hot. I re set the cable at the heater valve end and it has been fine since. 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Had some similar issues myself
Sometimes they would stay hot sometimes one side would be hot the other cold I found fitting a spring to the manifold helped somewhat I’ve ordered a replacement manifold to try try There’s quite a few that are the same eg Peugeot and Citroen etc 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
