Home > Maintenance & Modifications > Rear door - corrosion in bottom seam
Bluest
I’ve got corrosion on the bottom inside of the rear/safari door in my Puma. It is on the joint where the door skin is wrapped over along the bottom edge and I think it is from water that gets trapped there by the rubber seal when the door is shut. I understand it’s quite common and I’ve noted it for far too long. Has anyone got any ideas for successfully repairing and preventing it? With it being in a seam and in contact with door seal I can’t think of a way to repair it that will last and look satisfactory. 2007 110 TDCi Station Wagon XS
Post #984440 5th Mar 2023 10:56am
TexasRover
Clean it and then apply Fluid Film all over, all over the car in fact, reapply regularly
In my experience you cannot stop the rot with paint, you have to look at a removing dirt and then stabilise.
Post #984448 5th Mar 2023 11:44am
Balvaig
My 2011 Puma went in the same place.
Try repainting and then covering with a thin strip of helicopter tape along the seam. This will prevent rubbing on the seal, and as it is clear you can keep an eye on any future corrosion.
Check that the drainage holes are clear too.
Post #984457 5th Mar 2023 1:41pm
Bluest
It already got a bit flaky so more that just a repaint or treating is required I fear. I was tempted to abrade away as much rust as I could, apply rust converter, then seam seal for a smooth finish before repainting, but concerned ant remaining rot might fester under the seam sealer for bigger trouble down the line. 2007 110 TDCi Station Wagon XS
Post #984531 5th Mar 2023 9:04pm
Retroanaconda
Once the rust is in the seam you’ll never stop it I’m afraid. You might be able to slow down the spread a bit but it will travel between the panels and there’s no way to get effective treatment in there.
Post #984541 5th Mar 2023 10:16pm
