![]() | Home > In Car Electronics > Interior lights not turning off normally |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 397 ![]() ![]() ![]() |
Does the alarm work as you'd expect it to? I mean if you were to lock it with the window open does the alarm goes off if you were to reach in, unlock the door and open it?
The operation of the interior light is via its earth path. If you operate manually you create a route to earth on the black wire when you move the switch and then deny it the earth when you switch it off. The alarm control ECU controls the earth path when the interior light is allowed to be operated by the doors. It monitors the door switches and should illuminate when you unlock, keep the light on for a period after the door is closed and extinguish the light when you lock up. I'd be inclined to take the light unit out, identify the cable that is linked to the ECU earthing path (pink with white tracer) and connect a multi meter to it. Attach the black wire from your multi meter to a known good earth and check to see if you have continuity all the time. Make sure that pink/white wire isn't chafed or pinched where it goes down the A pillar, there's not much room behind the plastic trim and it very easy to pinch a wire when screwing it all back together, assuming it's been off before..ask me how I know! ![]() If you have a rear light check its wiring too as an earth fault there could also cause the same issue |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 435 ![]() ![]() ![]() |
thanks for the detaild reply! - i dont hae central locking but do have the impobaliser alrm - when i look the car it beeps the horn twice... thats why i was presuming it was the door switches - am i correct in that, that when the horn beeps twice the car thinks one door is open?
Yes, that's right. Somehow, you've got a permanent route to earth and the switches or the wiring to them are the obvious starting place. There's also a bonnet switch, too, but I can't remember if that's connected to the interior lights. Darren
the vehicle was resprayed after being taken before i brought it by someone who to say the least bodged up a number of things so i will have a look out chaffed wires and see if i can see if thre is awire somewhere that has been damaged etc. thanks for your advice guys.
As has been confirmed the double beep indicates the vehicle thinks a door is open, so the fault is unlikely to be in the A pillar loom. My next move would be to take out each door switch and connect one lead of a multimeter to the end of its wire and the other lead to a known good earth and check for continuity. If one of these door switch wires shows continuity then you’ve most likely found the wire that’s chafed and giving you the earth fault. The fun job is to then trace the wire and find it.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Probably one of the switches, or wet in the interior light on its rear connections.
It’s common for having some issue with interior lighting on Defenders. They’re always playing up. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Many thanks, will do this during one evening this week ad try find the fault. Again thanks. |
It would be an excellent idea to replace all of the door switches and their mounting screws as they corrode and either fail to work or work all the time.
Switch: AFU4241L Screw: YYP100860 The problem of lights on all the time cold be the wiring loom, as Penfold said, however it could also be the switch itself. The spade terminal is sandwiched in place by two flimsy bits of plastic and it has been known for the terminal to work loose and touch the main contact ring of the switch: Lights on. Good luck. |
Doobsn Member Since: 18 Jan 2023 Location: Bavaria Posts: 14 ![]() ![]() ![]() |
Hello,
some ideas already given in this thread. I also had this issue and suspected the switches at the door(s). My way of finding out what is wrong: - I removed all switches and isolated the cable ends (light should turn off) - I took a Multimeter and the checked if any of the open wires are connected to ground/earth - with my Defender it was located at the right hand side to have a permanent ground/earth connection After some time, I remebered, that I installed handle bars at the A-pillar, where the cables are routed, and I screwed the cable to the chassis. I was not able to lock the car from internal (I read you don't have central door locking), it opned right away. Maybe a possible solution for your problem. Kind Regards Tobias |
