![]() | Home > Maintenance & Modifications > Changing doors |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Is it possible to fit 2007 onwards Puma doors to a 90 300 tdi Defender? 1982 88" 2.25 diesel
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Yes, hence why so many later doors are nicked.
Thanks. Just something I have been mulling over. Bound to be expensive when all of the fittings are taken in account! 1982 88" 2.25 diesel
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2782 ![]() ![]() |
Very. But they are worlds better than the older pre-2005 doors.
Agreeded, that is why I am thinking of doing it to my daughter's 300 tdi 90. 1982 88" 2.25 diesel
Yes, they are a straight swap, although you may want to use period door handles and locks to retain the key types. I fitted them to my old 200tdi:
https://www.defender2.net/forum/post633316.html#633316 ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Nice and thank you for the link. It would be hard now since the Puma has been out of production for sometime to get a good set of used doors. Just wondered if any of the existing fittings, like glass, window mechanism (manual) etc could be reused with the Puma doors? 1982 88" 2.25 diesel
Most, if not all, is quite different unfortunately Darren
They are a heavier, thicker door and all steel. Fit better and draught free. 1982 88" 2.25 diesel
Came across this. Complete door including door card and fittings. Ready to fit!
https://www.sp-4x4.com/Tdci_Puma_land_rove...wp5063.htm 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
That’s not a bad option for a fully built up door, although all the parts inside will be aftermarket. I note they offer the choice of genuine for the latch, as the aftermarket ones of those are notoriously bad.
As above, heavier and stiffer. All steel so they don’t suffer from bimetallic corrosion. And available with electric windows and central locking as standard. Only downside is the cost. |
Never on any account use an aftermarket latch, learned that the hard way when it failed after a month. The build standards between the two are worth the cost of the OEM latches.
One of the things that was putting me off doing this, (apart from the cost
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I fitted 4 of the SP4x4 galvanised frame doors with zintec steel skin to my Td5 DCPU a few years back and reused the old innards. There's a high probability that you'll need to buy new door handles though because the fixing screws seize in the nutserts and break free of the plastic handle moulding. It's also worth renewing all the window rubbers and seals.
The replacement doors are still in perfect condition and I'd do the same again on another Defender if necessary. ![]() Click image to enlarge |
