Home > Maintenance & Modifications > Changing doors
spudfan
Ireland
Changing doors
Is it possible to fit 2007 onwards Puma doors to a 90 300 tdi Defender? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #980847 1st Feb 2023 7:36pm
htb2
Wales
Yes, hence why so many later doors are nicked.
Post #980851 1st Feb 2023 7:50pm
spudfan
Ireland
Thanks. Just something I have been mulling over. Bound to be expensive when all of the fittings are taken in account! 1982 88" 2.25 diesel
Post #980855 1st Feb 2023 8:05pm
Retroanaconda
Very. But they are worlds better than the older pre-2005 doors.
Post #980857 1st Feb 2023 8:27pm
spudfan
Ireland
Agreeded, that is why I am thinking of doing it to my daughter's 300 tdi 90. 1982 88" 2.25 diesel
Post #980864 1st Feb 2023 9:25pm
Yes, they are a straight swap, although you may want to use period door handles and locks to retain the key types. I fitted them to my old 200tdi:
https://www.defender2.net/forum/post633316.html#633316
 Darren
Post #980866 1st Feb 2023 9:42pm
spudfan
Ireland
Nice and thank you for the link. It would be hard now since the Puma has been out of production for sometime to get a good set of used doors. Just wondered if any of the existing fittings, like glass, window mechanism (manual) etc could be reused with the Puma doors? 1982 88" 2.25 diesel
Post #980873 1st Feb 2023 10:12pm
Most, if not all, is quite different unfortunately Darren
Post #980877 1st Feb 2023 10:23pm
wrcarter
Ireland 1989 Defender 110 200 Tdi CSW Portofino Red
Not to ask a stupid question but why are the so much better? Is it just they don’t rot as much? 1989 Land Rover 110 CSW
Post #980896 2nd Feb 2023 12:04am
spudfan
Ireland
They are a heavier, thicker door and all steel. Fit better and draught free. 1982 88" 2.25 diesel
Post #980901 2nd Feb 2023 1:20am
spudfan
Ireland
Came across this. Complete door including door card and fittings. Ready to fit!
https://www.sp-4x4.com/Tdci_Puma_land_rove...wp5063.htm 1982 88" 2.25 diesel
Post #980902 2nd Feb 2023 1:29am
Retroanaconda
That’s not a bad option for a fully built up door, although all the parts inside will be aftermarket. I note they offer the choice of genuine for the latch, as the aftermarket ones of those are notoriously bad.
As above, heavier and stiffer. All steel so they don’t suffer from bimetallic corrosion. And available with electric windows and central locking as standard. Only downside is the cost.
Post #980913 2nd Feb 2023 8:31am
kenzle8a
Never on any account use an aftermarket latch, learned that the hard way when it failed after a month. The build standards between the two are worth the cost of the OEM latches.
Post #980933 2nd Feb 2023 12:04pm
spudfan
Ireland
One of the things that was putting me off doing this, (apart from the cost Laughing ) was the number of items involved to get the complete door fitted out. Just making sure you have everything would be a logistical nightmare! The complete unit does seem a more convenient route. I note your comment about the use of after market non genuine fittings. Over the years when things have been repaired/replaced on my doors it is usually after market items that have been fitted and things have worked as they should. 1982 88" 2.25 diesel
Post #980934 2nd Feb 2023 12:08pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I fitted 4 of the SP4x4 galvanised frame doors with zintec steel skin to my Td5 DCPU a few years back and reused the old innards. There's a high probability that you'll need to buy new door handles though because the fixing screws seize in the nutserts and break free of the plastic handle moulding. It's also worth renewing all the window rubbers and seals.
The replacement doors are still in perfect condition and I'd do the same again on another Defender if necessary.
Post #981005 2nd Feb 2023 7:19pm
