Home > Td5 > Early/later Td5 bulkheads
Page 2 of 3 <123>
1NRO
Tried to paste pictures from John’s thread but they are just links, beyond my very limited IT skills.
Seems to me that removing the wiper motor mounting bracket from a later bulkhead gives a straight shot at mounting the wiper motor as found on earlier Td5’s.
Post #979611 24th Jan 2023 6:53pm
TexasRover
Interesting. I am in the process of stripping an early 1999 Td5 and have a later 2003 Td5 as well so looking at harvesting/swapping some parts over where beneficial.
Looks like apart from some holes and (I assume) permanent R380 tunnel v bracket, the wiper bracket is the biggest change.
What exactly is the improvement this wiper bracket makes? Less noise transmitted? As far as I can tell the motor assembly is the same no?
Post #979678 25th Jan 2023 8:50am
TexasRover
Actually just looked and there is a part number change at 2001
https://www.lrparts.net/rtc3867-front-wipe...-gear.html
https://www.lrparts.net/lr082012-front-wip...ables.html
But they look a bit the same.
Reason I am asking is that my 2003 has (what I think) a fairly loud wiper motor, but I never had the 1999 wipers working. I was thinking maybe something wrong with the 2003 wiper motor.
Anyway sorry for high jacking the thread..
Post #979679 25th Jan 2023 8:56am
excossack
Which pictures are you after? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #979683 25th Jan 2023 9:17am
1NRO
I was hoping to post the pictures from your thread that show the inside of your original and new bulkhead. The wiper motor is still attached to the original and it’s plain to see the change on the new.
Post #979687 25th Jan 2023 9:46am
1NRO
Can’t imagine there’d be much improvement with a new bracket but the raised position would be a more straight assembly which perhaps equals less strain.
Post #979688 25th Jan 2023 9:57am
TexasRover
Actually looking at the two again, it looks like the heater box opening is larger which would have interfered with the (old) wiper motor location.
So really they fitted a bracket to raise the wiper motor to accommodate a larger heater??
Fascinating the anatomy of cars I find. Small difference for a reason
Post #979691 25th Jan 2023 10:11am
excossack
Okey dokey. I see you got both pics in page 1 of this topic. 1999 Defender TD5 110
Regards
John M0VAZ
Post #979692 25th Jan 2023 10:11am
Martin
Site Admin
I changed the links to embedded photos Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #979694 25th Jan 2023 10:16am
1NRO
Thanks Martin
Post #979697 25th Jan 2023 10:45am
rallysteve
1NRO wrote:
Later bulkhead
Interesting, my 02' TD5 bulkhead does not have either of the holes in the centre (oval and rectangular)! No idea what they are for?
Post #979700 25th Jan 2023 11:01am
TexasRover
Here are my 1999 RHD (UK) bulkhead pictures for reference
Post #979706 25th Jan 2023 11:35am
excossack
I ordered mine new from Land Rover (Duckworths) so I wonder if it was made later towards the Puma era of bulkheads hence the extra holes? 1999 Defender TD5 110
Regards
John M0VAZ
Post #979710 25th Jan 2023 11:44am
excossack
Is the larger hole for Puma heaters?
I can't recall if the hole was made smaller with a plate or left as is when the work was done. 1999 Defender TD5 110
Regards
John M0VAZ
Post #979711 25th Jan 2023 11:48am
rallysteve
Possibly so, the heater hole above the passenger footwell is definitely larger on yours. I guess they possibly make a basic bulkhead and just weld a few brackets on to suit TD5 or TDCI rather than having totally different pressings. 02' 110 TD5 Double Cab Rebuild Thread
Post #979712 25th Jan 2023 12:11pm
Page 2 of 3 <123>
