Home > Maintenance & Modifications > Swivel Kit for 2011 Puma
ChrisDefender
Hi,
I have a slight leak on one of the swivels, so it needs changing. The casing and ball look to be all fine so guess its just the seals etc I need to order.
I have searched on here and online and I can only seem to find a Britpart Kit which I presume will be useless, does anybody have a complete list of the parts I need to order (for one side and I will double up) which I can then give to my local indy?
Any help on a complete list is gratefully received as it looks like there are a lot of small parts. It's for a Puma 90 2011HT.
Cheers.
Post #978329 16th Jan 2023 2:55pm
BrickBox
Try Advanced Factors. They’ll have the quality parts your after.
https://www.advancedfactors.co.uk/land-rov...16-5-c.asp 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #978338 16th Jan 2023 3:24pm
ChrisDefender
Hi, thank you, indeed they do, but just which kit I need I am still at a loss to work out. They all look like BP kits to me (to the untrained eye!).
I guess I will have to give them a call and trust them. I just don't know what the LA to WA etc means!
I have a 2011 90 HT non ABS basic truck.
Post #978340 16th Jan 2023 3:30pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Chris, be interested to find out how you get on as I've the same job to do on mine Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #978342 16th Jan 2023 3:36pm
ChrisDefender
Hi,
I'll let you know if I ever work it out. To a non-mechanic it's a nightmare Laughing
Post #978343 16th Jan 2023 3:37pm
ChrisDefender wrote:
... I just don't know what the LA to WA etc means!
The LA / WA malarky is the parts catalogue clear-as-mud method for identifying model year. Characters 10 and 11 of the VIN will either be two letters, or on later vehicle a digit and a letter, and it is the tenth letter or digit (L and W in your examples) which identifies the year. The 11th character A indicates built at Solihull, which of course all proper Defenders were.
L means '93/'94, W means '97/'98. The letter code has wrapped around as well, and I would expect that your 2011 vehicle probably has a VIN containing "BA" (it could be AA or CA depending on when it actually rolled down the line).
I suggest that for a fuller understanding you visit a website such as this one which explains the whole VIN comprehensively (on this particular site, click the character of interest in the VIN for an explanation).
AS far as your leak is concerned, it is possible that the swivels have worn and this has allowed the swivel housing to move slightly on the ball, resulting in a leak. Before committing to a full overhaul, it is worth checking for movement in the swivels since if there is movement you may be able to remove a shim to take up the lost movement and then recentre the seal on the ball to stop the leak. THis can work if the cause is movement in the swivels rather than a knackered seal.
If the swivels are in good order but the seal in knackered, then a new seal is the answer. There are those who fit the seals by cutting them (so that the swivel ball doesn't have to be removed from the axle) but personally this is not an approach I would use. It is possible to withdraw the complete assembled ball, swivel housing and hub from the axle after the brake hose is disconnected (or the caliper is unbolted) and this allows the seal to be fitted properly (the assembly is heavy though).
If the swivels and the seal are all knackered, then it is time for a full overhaul.
Post #978346 16th Jan 2023 4:00pm
ChrisDefender
Hi Blackwolf, thank you very much, that explains things a little. You're right in that I have BA in my number, and from that site I can see the exact date it was built.
I have contacted A Factors and they are hopefully getting back to me as to which kit I need that has the Timkin bearings rather than BP ones.
I still don't fully understand what I need but I am getting closer! I will get my mechanic to have a good look. Thumbs Up
Post #978347 16th Jan 2023 4:06pm
If you want a further opportunity for confusion, the earlier vehicles with essentially the same axle (TD5 vehicles) used a bearing on the one of the pins (but I can't remember which, I think upper) with a conventional full array of rollers. This was "value engineered" on later vehicles to get rid of half the rollers and uses a nylon spacer to keep the few remaining rollers in the right place. Guess which version your vehicle will have been built with? Guess with version is stronger and will last longer? Yup, you guessed both!
It is quite a sensible upgrade to fit the earlier bearings, if you can find them, in place of the later ones. Unfortunately I don't have the part numbers to hand, but I will see if I can dig them out.
Post #978350 16th Jan 2023 4:19pm
Part numbers, Defender 2007 on (from LRCAT):
Upper pin: TAR100040 - this is a service kit consisting of the pin which incorporates the inner race of the bearing, the bearing, the outer race, and an O-ring.
Bearing for lower pin: 606666
Gasket for lower pin: FTC3674
Shims for upper pin to set preload:
.003" = FRC2883
.005" = FRC2884
.010" = FRC2885
.030" = FRC2886
You are likely to need a selection but you won't know what until you do the job, you can of course reuse the originals (if there are any) but don't assume that the originals alone will allow you to set the correct bearing preload.
Oil seal for the ball (the big one): FTC3401
The top pin was different on earlier vehicle as I mentioned. If you want to retrofit the stronger top bearing, you would need to use pin FTC2882 with bearing 60666 (identical to the bottom bearing) instead of TAR100040. The advantages are that the bearing is stronger and the inner race is not integral to the top pin. The same shims are used with either type. This configuration was used on VINs from LA930456 to XA159806.
Post #978354 16th Jan 2023 4:37pm
ChrisDefender
Hi,
Thank you for taking the time to explain this and list parts etc, it is all getting quite overwhelminig!
Excuse my ignorance, but does this mean all the parts I need to complete the job (for the replacement of seals) are listed in your above post?
If so that is fantastic.
Just to be sure the Gasket for lower pin: FTC3674 is showing up in a search as a clip?
Thank you.
Post #978358 16th Jan 2023 4:52pm
hxk494
it's just a typo - FTC3647 1996 300Tdi Defender 110
Post #978377 16th Jan 2023 6:20pm
geobloke
Hi,
Ok, it is not a difficult task as long as you follow the manual and work methodically. The other advice I would give is to make sure during refitting you keep everything as clean as possible, especially when working out the shims and preload. On that note the easiest way I have found to calculate the correct shim thickness is using some thickish soulder. It compresses easily and all you have to do then is use a micrometer to work out the shim thickness. This is a great first thickness to start with, if not enough preload remove a small shim, etc. etc.
Good luck Thumbs Up
Post #978380 16th Jan 2023 6:28pm
This, thank you hxk. My error swivel-chairing between screens.
Post #978405 16th Jan 2023 8:43pm
Porny
Site Sponsor
Some Britpart Stuff is actually pretty good - you just need to know what you are buying.
As your Defender is none ABS - you can use kit DA3179PG which uses all OEM parts. All in one kit.
(PM me if I can help)
This kit comes with Timken Bearings etc etc (and I've used quite a few of them - along with full Swivel Kits).
I'm surprised your independent is fitting customer supplied parts - something I would never do as generally hassle and a big no no from my insurance company. (Also makes me liable for any failures as a disclaimer means nothing)
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #978434 16th Jan 2023 11:55pm
TC909
I have a full kit that I purchased from Rimmer bros but caved and let the garage do it instead.
Its for a 08 Puma so would work. Drop me a PM if interested and I'll send over the part numbers Smile
Post #978455 17th Jan 2023 9:08am
