![]() | Home > Puma (Tdci) > Heated Windscreen Switch = No Light |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 695 ![]() ![]() ![]() |
I suspect you need the engine running, relay will take alternator voltage signal. 130 Puma HCPU with an Artica 240LR Demountable Camper
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1105 ![]() ![]() ![]() |
I believe it only works with the engine running. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18026 ![]() ![]() ![]() |
As above, the HFW requires the engine to be running in order to work. The is.an "engine running" signal from the IPAC which is used for this purpose (which if I remember is actually dependent upon the alternator providing an output which means the engine is running).
Start your engine and repeat your test, let s know how you get on. |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 77 ![]() ![]() ![]() |
Cheers chaps
Engine running and still no joy Engine running. Switch pressed. No light on HWS button |
Is it factory-fitted or aftermarket?
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 ![]() ![]() ![]() |
factory spec?
Yeah. Factory fitted
is it working, just no switch light? or all DOA?
Completely dead. Not working at ll
is the relay clicking?
No. Nothing when the button is pressed. Switched the relays around as well to test and nothing
![]() Click image to enlarge Could be the realy OR the timer... |
The switch light (AKA tell tail) is wired to the timer, so if the timer is duff you will not get a light oin the switch, the realy may still work but the timer may not be actuating!
Awesome, thanks. Need to see if i can find a spare one to test.
Thansk |
