Home > Puma (Tdci) > Heated Windscreen Switch = No Light
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi all
Having a nightmare troubleshooting this issue.
Car has ignition on but when I press the heated windscreen, I do not get a light on the switch.
I have also moved the relays about to try and troubleshoot under the steering wheel and the relays look to be working.
Any ideas on what to next try?
Thanks
Nick.
Post #976403 2nd Jan 2023 6:08pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I suspect you need the engine running, relay will take alternator voltage signal. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #976406 2nd Jan 2023 6:29pm
BrickBox
I believe it only works with the engine running. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #976408 2nd Jan 2023 6:50pm
As above, the HFW requires the engine to be running in order to work. The is.an "engine running" signal from the IPAC which is used for this purpose (which if I remember is actually dependent upon the alternator providing an output which means the engine is running).
Start your engine and repeat your test, let s know how you get on.
Post #976409 2nd Jan 2023 6:55pm
nick.bw
Cheers chaps
Engine running and still no joy
Engine running. Switch pressed. No light on HWS button
Post #976421 2nd Jan 2023 7:44pm
Is it factory-fitted or aftermarket?
Post #976442 2nd Jan 2023 9:16pm
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
factory spec?
Post #976446 2nd Jan 2023 9:35pm
nick.bw
Yeah. Factory fitted
Post #976447 2nd Jan 2023 9:36pm
KISSMYAURA
is it working, just no switch light? or all DOA?
Post #976461 2nd Jan 2023 10:05pm
nick.bw
Completely dead. Not working at ll
Post #976494 3rd Jan 2023 10:28am
KISSMYAURA
is the relay clicking?
Post #976495 3rd Jan 2023 10:33am
nick.bw
No. Nothing when the button is pressed. Switched the relays around as well to test and nothing
Post #976496 3rd Jan 2023 10:33am
KISSMYAURA
Could be the realy OR the timer...
Post #976497 3rd Jan 2023 10:35am
KISSMYAURA
The switch light (AKA tell tail) is wired to the timer, so if the timer is duff you will not get a light oin the switch, the realy may still work but the timer may not be actuating!
Post #976498 3rd Jan 2023 10:36am
nick.bw
Awesome, thanks. Need to see if i can find a spare one to test.
Thansk
Post #976499 3rd Jan 2023 10:38am
