|  | Home > Puma (Tdci) > Transfer box selector gone sloppy |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | There are value-engineered plastic connectors in the linkage and it is possible that one has come unclipped. There are also bits which can break. If you have a look from underneath ideally with someone else waggling the lever you can probably see what's gone wrong. From your description it is unlikely to be inside the transfer box. | ||
|  28th Dec 2022 8:39am |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3654      | Someone else on this forum is also looking for that link. Seems to be a common failure (mine was replaced by previous owner).
 https://www.defender2.net/forum/topic85961.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black | ||
|  28th Dec 2022 8:49am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | I've just seen the price of the replacement part from LR (and it's not available aftermarket as far as I can tell), around £220 for a piece of plastic tat!    | ||
|  28th Dec 2022 11:18am |
| Coops Member Since: 20 Jan 2022 Location: Cambridgeshire Posts: 16    | Thanks blackwolf and dinnu…took a look underneath and it was the control rod thing. The plastic connector had popped off and was hanging down. A bit tight to reach but popped back on (photo)…yet to road rest but hopefully ok | ||
|  28th Dec 2022 2:25pm |
| Posting Rules
