Home > For Sale & Wanted > [Wanted] Puma High/Low Selector Rod
hank
Evening all
I am after a Puma high/low selector rod if anybody has one knocking about? The rod with ball joints either end - pictured below circled red
If you have anything let me know. Thanks
 > 110 XS Double Cab
Post #975279 20th Dec 2022 5:08pm
hank
Pleeeaaase Bow down > 110 XS Double Cab
Post #975371 21st Dec 2022 3:31pm
Dinnu
Just a thought... wonder if the ends of the gas struts as fitted to rear door of a small hatchbacks would fit (with a piece of threaded rod). Those ends of gas struts are usually screw on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975373 21st Dec 2022 4:00pm
hank
Yeah I think the balls are 10mm so if worst comes to the worst I can make up an adjustable rod with ball socket ends. I would rather the real deal though... > 110 XS Double Cab
Post #975374 21st Dec 2022 4:10pm
At over £220 the genuine part is disturbingly expensive for a piece of old tat! No surprise there.
How about a couple of these (or similar equivalents) with a length of threaded rod?
https://www.cromwell.co.uk/shop/bearings-a...UN6792806K
Similar items available from Amazon:
https://www.amazon.co.uk/KJBGS-Bearing-Con...80242?th=1
Post #975856 28th Dec 2022 10:49am
For info I have just measured the balls on a spare gearbox and selector tower and can confirm that the balls are 10mm diameter.
It's relatively easy to find DIN 71805 ball sockets for 10mm balls, which would mean that making up a replacement linkage should be straightforward (and cost a lot less than £220).
Post #976074 30th Dec 2022 1:44pm
I've got loads of gas struts at work from old fruit machines. I can measure the ball on Tuesday if they're 10mm then can chop the "ram" off of one of the struts. one end is pre threaded so you'd just need to cut a thread on the other end and screw on the ball clamp bit (got plenty of those too)
Post #976075 30th Dec 2022 2:19pm
