![]() | Home > Puma (Tdci) > Low power in 6th gear |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
my defender puma 90 2.4 does the same in 6th gear when I press the accelerator pedal below 2000 it's as if I'm accelerating in a vacuum. but I think I have found the problem it is a lack of fuel tank clogged for the moment I have sent injector cleaner, antibacterial water dispersant several times, I have an improvement but not completely I must still have dirt in the tank I also changed the fuel filter several times but the best would be to drop the tank to clean it
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21005 ![]() ![]() |
Failing VCV does this. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
JakkalsOO Member Since: 15 Mar 2023 Location: Kempton Park Posts: 4 ![]() ![]() ![]() |
Has any one been able to resolve the low power in 6th gear issue?
I have replaced the VCV valve and no improvement. |
ScottieG71 Member Since: 13 Mar 2023 Location: Alberta Posts: 6 ![]() ![]() ![]() |
I read in another forum not to run RPMS less than 1800...i will try to find the article...
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 997 ![]() ![]() ![]() |
Have you checked your hoses for splits? Sounds like it could possibly be a split in the hose to your turbo?
Jim |
Thank you for the replies.
I have checked the hoses, have done a pressure test on the boost system, while the engine is off. It doesn't have any leaks. When I drive the vehicle, it performs well, until I go up an uphill, then it looses power and then when one feathers the throttle it increases the performance again. When running diagnostics I can see that when this occurs the fuel rail pressure drops to +-1200bar from +-1600bar. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18003 ![]() ![]() ![]() |
My 2.4 Puma pulls like the proverbial train from about 1100 rpm, and pulls well in all gears including 6th. It has an early (c.2010) BAS remap, from the days before Pete offered two power options, and it was pretty feeble before this. The map's been on for 13 years and over 210k miles.
I don't think I've ever revved the engine over 3k and I'm not sure I'd want to. |
Why on earth would anyone want to do this? |
