Home > Maintenance & Modifications > Spotlamp location - MOT fail?
seriesonenut
You know how it is, Christmas eve and suddenly you remember the set of Hella 3000 Rallye lamps sitting in the garage.
So with a bit of ingenuity involving angle iron and G clamps this seems the only place they could go without buying a soft a bar.
Some will hate the look but I like the retro vibe and these remind me of the Cibie Oscars I once had on a td csw.
The question is would that be illegal? I cant try to check the pattern of the light beam just yet so before I get all carried away is it a non starter?
hella1 by Richard Holmes, on Flickr
hella2 by Richard Holmes, on Flickr
I think the only other option is to go for an A bar setup but ther £300 + price tag is putting me off...... 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #975663 24th Dec 2022 4:57pm
Why not move them inboard and mount your number plate higher?
Post #975665 24th Dec 2022 5:00pm
seriesonenut
The Air-con grill sits too far forward to do that unfortunately 1984 One-Ten CSW
2010 XS USW (sold)
Post #975667 24th Dec 2022 5:09pm
Why not move them inboard and further forward and mount the number plate higher? Very Happy
I suspect your only legal issue would be if the beam cut-off was compromised and the top part of the lens and reflector are more significant than the bottom in that respect, but they will cast a big shadow exactly where you don't want one.
Alternatively stick them on eBay and use the proceeds to buy a smaller modern light which works better!
Post #975669 24th Dec 2022 5:20pm
LR Nuts
put them back in the garage Rolling with laughter
they just don't look right .
Post #975678 24th Dec 2022 6:30pm
ickle
I had KC daylighters (6") and now Warn dipping G4 approx 6 1/2" across in that position, straight through the top of the bumper without ever having a problem - but those Hellas do look a tag larger...
HTH Keith
Post #975679 24th Dec 2022 6:32pm
cee-b
This is what the Road Vehicle Lighting Regs says:
2.  Position–
(a) Longitudinal:
No requirement
(b) Lateral–
(i)Where a pair of front fog lamps is used in conditions of seriously reduced visibility in place of the obligatory dipped beam headlamps–
Maximum distance from side of vehicle:
400 mm
(ii)in all other cases:
No requirement
(c) Vertical–
(i)Maximum height above the ground–
(A)Any vehicle not covered by sub-paragraph (B):
1200 mm
Surprisingly, The MOT Testers' Manual doesn't say anything about position (I think it used to) so it can't legally be an MOT fail regardless of where you put them. the only issue might be if they are deemed to interfere in any way with the headlight beam.
https://www.gov.uk/guidance/mot-inspection...tion-4-5-1
But, on a personal level, I don't think they look right Neutral
Post #975680 24th Dec 2022 6:40pm
bankz5152
Non issue.
Like the retro look!
Post #975681 24th Dec 2022 7:11pm
Litch
Personally I love the retro look and have traditional Hella spots on my bumper however I don't have the aircon grill that you do but mine still sit proud (I do have a Nakatanenga grill that is flush).
If you wanted to reduce the impact you could cut a few slats out of the plastic grill directly behind to reduce the overhang (I did this years ago with a different set of lights).
 ONE LIFE, GET IT!
Post #975684 24th Dec 2022 7:31pm
Litch
Hopefully a better photo showing the overhang.
You would probably need a flat bracket to push yours further forward.
 ONE LIFE, GET IT!
Post #975686 24th Dec 2022 7:38pm
I also have 6" KC's . limited as to where I can fit mine because of the Husky, but this size and placement don't give any issues,
Post #975703 25th Dec 2022 10:58am
LR Nuts
Just don't go the whole hog Rolling with laughter Rolling with laughter
Post #975708 25th Dec 2022 1:21pm
Stacey007
Could you fit / make like a plinth the type that you put car badges on? AA / RAC and put them closer to the center of the grille?
This type of idea
https://www.masai4x4.com/Bumper-Light-Bar-...-p43564713
https://www.ebay.co.uk/itm/144594621988?ha...R8zyoOKpYQ
Post #975747 26th Dec 2022 12:15pm
seriesonenut
Thanks Stacey007, the Masia bar might work. 1984 One-Ten CSW
2010 XS USW (sold)
Post #975752 26th Dec 2022 12:58pm
cretesimon
Greece
Fit them and just remove for mot hahaha
Post #975782 27th Dec 2022 8:16am
