![]() | Home > Maintenance & Modifications > Spotlamp location - MOT fail? |
| seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1265
You know how it is, Christmas eve and suddenly you remember the set of Hella 3000 Rallye lamps sitting in the garage.
So with a bit of ingenuity involving angle iron and G clamps this seems the only place they could go without buying a soft a bar. Some will hate the look but I like the retro vibe and these remind me of the Cibie Oscars I once had on a td csw. The question is would that be illegal? I cant try to check the pattern of the light beam just yet so before I get all carried away is it a non starter? hella1 by Richard Holmes, on Flickr
hella2 by Richard Holmes, on Flickr
I think the only other option is to go for an A bar setup but ther £300 + price tag is putting me off...... 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Why not move them inboard and mount your number plate higher?
Why not move them inboard and further forward and mount the number plate higher?
I suspect your only legal issue would be if the beam cut-off was compromised and the top part of the lens and reflector are more significant than the bottom in that respect, but they will cast a big shadow exactly where you don't want one. Alternatively stick them on eBay and use the proceeds to buy a smaller modern light which works better! |
| LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1316
put them back in the garage
they just don't look right . |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Click image to enlarge I had KC daylighters (6") and now Warn dipping G4 approx 6 1/2" across in that position, straight through the top of the bumper without ever having a problem - but those Hellas do look a tag larger... HTH Keith |
| cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117
This is what the Road Vehicle Lighting Regs says:
2. Position– (a) Longitudinal: No requirement (b) Lateral– (i)Where a pair of front fog lamps is used in conditions of seriously reduced visibility in place of the obligatory dipped beam headlamps– Maximum distance from side of vehicle: 400 mm (ii)in all other cases: No requirement (c) Vertical– (i)Maximum height above the ground– (A)Any vehicle not covered by sub-paragraph (B): 1200 mm Surprisingly, The MOT Testers' Manual doesn't say anything about position (I think it used to) so it can't legally be an MOT fail regardless of where you put them. the only issue might be if they are deemed to interfere in any way with the headlight beam. https://www.gov.uk/guidance/mot-inspection...tion-4-5-1 But, on a personal level, I don't think they look right |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Non issue.
Like the retro look! |
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
Personally I love the retro look and have traditional Hella spots on my bumper however I don't have the aircon grill that you do but mine still sit proud (I do have a Nakatanenga grill that is flush).
If you wanted to reduce the impact you could cut a few slats out of the plastic grill directly behind to reduce the overhang (I did this years ago with a different set of lights). Click image to enlarge Click image to enlarge ONE LIFE, GET IT! |
Hopefully a better photo showing the overhang.
You would probably need a flat bracket to push yours further forward. Click image to enlarge ONE LIFE, GET IT! |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
Click image to enlarge I also have 6" KC's . limited as to where I can fit mine because of the Husky, but this size and placement don't give any issues, |
Click image to enlarge Just don't go the whole hog |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3898
Could you fit / make like a plinth the type that you put car badges on? AA / RAC and put them closer to the center of the grille?
This type of idea https://www.masai4x4.com/Bumper-Light-Bar-...-p43564713 https://www.ebay.co.uk/itm/144594621988?ha...R8zyoOKpYQ |
Thanks Stacey007, the Masia bar might work. 1984 One-Ten CSW
| cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 64
Fit them and just remove for mot hahaha
| All times are GMT |
