Home > Maintenance & Modifications > Has anyone fitted a Fayou brand heated windscreen?
murph81
Ireland 2007 Defender 110 Td5 PU Belize Green
I had a heated windscreen fitted a while back since the old screen and seal needed replacing.
I am only getting around to working it up now and I don't know which side of the screen is positive and which side is negative.
It's a Fayou brand screen, I wont be able to contact the supplier until tomorrow.
Can anyone point me in the right direction, I wouldnt have thought the polarity of the screen would have mattered but it says so in the instructions of the wiring kit.
I'd really like to get it going tonight.
Post #975299 20th Dec 2022 8:16pm
murph81
Looks like I'm screwed for the moment, screen is using more current by the looks of things.
I'm using a Britpart witing kit and it's only rated for 20 amps, I've read elsewhere that the Fayou screen needs 30 amps.
I'm hoping I can just upgrade the supply to the screen, the earth and the relays.
Post #975315 20th Dec 2022 11:23pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
The polarity of the screen shouldn't matter, just like a bulb it is simply a case of current flowing through filaments that get warm.
In my experience with HFS on Land Rover, Ford and Volkswagen the circuit protection is well in excess of 20 amp, my screen is protected by a 40 amp fuse and similar rated relay. Those tiny filaments offer up very little resistance hence the current is so high. Ohm's law and all that stuff we learnt at school but never put into practical use! V = I x R or in this case I = V/R
The very high current is the reason why on a factory fitted HFS the screen will not function if the engine is not running (sensed from the oil pressure switch). A very fast method of draining your battery otherwise.
Post #975319 21st Dec 2022 12:35am
murph81
Thanks Penfold, looks like polarity is not an issue.
The issue now is the wiring kit, I knew I should have waited and got a decent kit from Pace Automotive or the likes.
Post #975350 21st Dec 2022 11:33am
Porny
Site Sponsor
As far as i'm aware the only kit rated higher is from Tim at Mobilecentre... all the other copy kits have all copied the Britpart version (also made by Mobilecentre - but Britpart wanted to keep price down).
You can tell the HD version, as Mobile centre use an extra relay to control the actual feed to the screen rather than relying on the orange time relay. Woudn't be hard to modifiy the Britpart loom you have. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #975492 22nd Dec 2022 5:05pm
