![]() | Home > Maintenance & Modifications > Has anyone fitted a Fayou brand heated windscreen? |
murph81 Member Since: 11 Sep 2022 Location: Ireland Posts: 63 ![]() ![]() ![]() |
Looks like I'm screwed for the moment, screen is using more current by the looks of things.
I'm using a Britpart witing kit and it's only rated for 20 amps, I've read elsewhere that the Fayou screen needs 30 amps. I'm hoping I can just upgrade the supply to the screen, the earth and the relays. |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
The polarity of the screen shouldn't matter, just like a bulb it is simply a case of current flowing through filaments that get warm.
In my experience with HFS on Land Rover, Ford and Volkswagen the circuit protection is well in excess of 20 amp, my screen is protected by a 40 amp fuse and similar rated relay. Those tiny filaments offer up very little resistance hence the current is so high. Ohm's law and all that stuff we learnt at school but never put into practical use! V = I x R or in this case I = V/R The very high current is the reason why on a factory fitted HFS the screen will not function if the engine is not running (sensed from the oil pressure switch). A very fast method of draining your battery otherwise. |
Thanks Penfold, looks like polarity is not an issue.
The issue now is the wiring kit, I knew I should have waited and got a decent kit from Pace Automotive or the likes. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
As far as i'm aware the only kit rated higher is from Tim at Mobilecentre... all the other copy kits have all copied the Britpart version (also made by Mobilecentre - but Britpart wanted to keep price down). You can tell the HD version, as Mobile centre use an extra relay to control the actual feed to the screen rather than relying on the orange time relay. Woudn't be hard to modifiy the Britpart loom you have. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
