Home > Puma (Tdci) > High cap to Staion Wagon conversion
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Hi,
Planning to convert my high capacity 110 to SW 110.
My chassis number confirms it is not the heavy duty version, so does it have the exactly same version coil spring as a genuine 110 Station Wagon?
Does anybody know the functional difference between the self leveling shock (mono shock) and the anti roll bar?
Thanks alot Very Happy
Post #97323 31st Oct 2011 4:11pm
T1G UP
the self leveller levels....the ARBs stop body roll. Quite different.
You can remove the self leveller.
quite a bit of bodywork to change from a HC to a SW...good luck
Post #97350 31st Oct 2011 6:35pm
dilukabey
[quote="T1G UP"]the self leveller levels....the ARBs stop body roll. Quite different.
quite a bit of bodywork to change from a HC to a SW...good luck[/quote]
Yes, I have ordered all bit and pieces like rear tub, doors, roof, interior panels, nut, bolts, mounts, seats, hinges etc.
Could you please tell me anything I have to be concerned when doing the conversion? Because this my first one Crying or Very sad
Post #97432 1st Nov 2011 3:06am
A friend of mine converted a Stage 1 V8 hi-cap to a station wagon a few years ago, but he did it by swapping the body with a regular Series III sw. That was a pretty mammoth task, so I don't envy you doing it from a kit of parts.
A lot of LR assemblies seem to have been pared down to the minimum since Series III days though, so are you sure that the chassis has all the necessary mounting points for a sw body? Darren
Post #97449 1st Nov 2011 9:19am
dilukabey
Hi Darren,
Thanks for the comment.
Yes I have ordered the body parts of a puma 2008 station wagon including chassi mounts. Very Happy
Post #97530 1st Nov 2011 5:55pm
