![]() | Home > Puma (Tdci) > High cap to Staion Wagon conversion |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hi,
Planning to convert my high capacity 110 to SW 110. My chassis number confirms it is not the heavy duty version, so does it have the exactly same version coil spring as a genuine 110 Station Wagon? Does anybody know the functional difference between the self leveling shock (mono shock) and the anti roll bar? Thanks alot ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
the self leveller levels....the ARBs stop body roll. Quite different.
You can remove the self leveller. quite a bit of bodywork to change from a HC to a SW...good luck |
[quote="T1G UP"]the self leveller levels....the ARBs stop body roll. Quite different.
You can remove the self leveller. quite a bit of bodywork to change from a HC to a SW...good luck[/quote] Yes, I have ordered all bit and pieces like rear tub, doors, roof, interior panels, nut, bolts, mounts, seats, hinges etc. Could you please tell me anything I have to be concerned when doing the conversion? Because this my first one ![]() |
A friend of mine converted a Stage 1 V8 hi-cap to a station wagon a few years ago, but he did it by swapping the body with a regular Series III sw. That was a pretty mammoth task, so I don't envy you doing it from a kit of parts.
A lot of LR assemblies seem to have been pared down to the minimum since Series III days though, so are you sure that the chassis has all the necessary mounting points for a sw body? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Hi Darren,
Thanks for the comment. Yes I have ordered the body parts of a puma 2008 station wagon including chassi mounts. ![]() |
