![]() | Home > Puma (Tdci) > Cold start issues |
ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52 ![]() ![]() ![]() |
Regarding the issue of not getting up to temp, this thread should be of use:
https://www.defender2.net/forum/topic71379.html |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 265 ![]() ![]() ![]() |
Ok
so an update on this , further cold weather today and further issues starting , turns over well but took a long time to catch and sounded lumpy No issues when hot new battery no stored fault codes different diesel gauge fill up ran a tail of injector cleaner through it as well its fairly slow to come to temp would be the only other issues with only done 32k I have 2.4 100 as well , this starts fine no issues , glow plugs stay on for at least 6/7 sec on the 2.4 barely 2/3 sec s on the 2.2 I am thinking some kind of temp sensor not pulling in the glow plugs for long enough any more ideas or what to check? |
another update
there is no cht sensor on 2.2 just coolant temp sensor checked this on cold start and temp was 2 degc so about right, no fault codes no blown fuses glow light stays on for 3 sec max turn key again and it briefly flashes then goes off still poor starting help! |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
![]() Click image to enlarge Roaming around 🇳🇴🇨🇭 |
is that right, where is it then ? has anyone got a colour pic?
on 2.4 its down back of the engine connector is on top in line with oil filler nothing there on mine uk spec 2015 ht? |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
Keith apologies I've only just spotted this. I've fitted an Yuasa HSB020 from Halfords. They had an old price on the shelf which was cheaper than the 019, which thankfully they honoured, less a 10% discount as an AA member (a scheme which I think they've now dropped) plus a further 8% through a voucher scheme via my employer. So all in all I got a bit of a steal I think lol. Dropped straight in without any issues. ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Dean, does this help?
Taken from here https://www.defender2.net/forum/post144576.html 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
hi
thats on a 2.4 , on a 2.2 its not there , and i cannot figure out where the earlier black and white drawing is in the engine bay i have the sensor and the socket but cannot find where it is on the 2.2? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17857 ![]() ![]() ![]() |
Most of the Ford forums etc seem to suggest that the CHT is in roughly the same place on both the 2.4 and 2.2 engines, which in the light of your comments is strange.
Perhaps you don't have one, and that is why you have an issue! |
bizarre
will nip out and take a pic , no connector there at all felt doen back and cannot feel another cable gong anywhere its been fine since new with cold start until just before Christmas so i would assume its got one as i have no dtc codes last fews months really difficult , its not the type of this to drop off is it! will post a pic of mine |
Having scoured the diagrams on lrworkshop.com, I'd say there isnt one.
Clearly listed on the 2.4, item 11 https://www.lrworkshop.com/diagrams/land-r...head_44989 Nothing for the 2.2 https://www.lrworkshop.com/diagrams/land-r...ad_2.2tdci Even went through the electrical components list they have and it was the same result. Odd there isnt one. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
hi that where I am at the moment
2.2 defender doesn't have one 2.4 does so as far as I can see glow plugs must use coolant temp sensor in hose as trigger for glow plug any more ideas what is holding the glow plugs to only 2/3 secs use? Struggling now! |
I'm pretty sure that 2-3 seconds is quite normal for a 2.2. That's certainly what mine seems to do and it starts without issue. Darren
ok thanks so that's the timing sorted if its normal
I have no fault codes regarding the glow plugs, as they are hard to get to I haven't tested or removed them no blow fuses its a 35k mid car but used for relatively short trips ,(wife's a nurse) could they be sooted up?, I have put a double dose of injector cleaner through it, to no noticeable difference I have bought a set go glow plugs as next step if no there ideas, they haven't really had that much use however? its been fine up to this year, never had an issue till this winter new battery as well and 100% charged any more collective knowledge |
