![]() | Home > Puma (Tdci) > 2.2 Puma throttle pedal issue |
dannyragsdale Member Since: 07 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 ![]() ![]() ![]() |
I have a similar issue and I'd be curious if anyone has an answer.
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
check the low range sensor on the transfer box. when the ecu thinks you are in low it changes the mapping to what you are describing Roaming around 🇳🇴🇨🇭
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
Clutch switch possible, bridge it to see if it is culprit you’ll soon know.
If it seems better all of a sudden, leave it bridged or replace clutch switch. I can’t say it is that, but worth investigating as clutch switch cuts torque and can cause a rev hang as well. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Finally got around to bridging the clutch switch and made a world of difference. The throttle responds immediately and doesn't hang anymore. Thanks for that tip!
Not sure if it's me getting used to the difference in response now, but the throttle is pulsing now. It doesn't do it all the time, but I either have to put my foot into the throttle or let off completely to not pulse. There doesn't seem to be an in between. Any thoughts on that? Thanks! |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 106 ![]() ![]() ![]() |
I spent nearly a year tracking down a pulsing throttle on my 2.2. Turned out to be wear on the loom where it comes through under the body, rubbing against the tub. Had worn through and was shorting on the bodywork.
Worth checking out as it was easy to spot once worked out. |
