Home > Puma (Tdci) > 2.2 Puma throttle pedal issue
Codee89
United Kingdom 2012 Defender 130 Puma 2.2 SW Bali Blue
Evening,
I have a 2.2 Puma with no power on throttle. Drives but takes a while to get the speed up. When releasing throttle pedal there is a good few second delay before revs drop.
No fault codes but the throttle position sensor only reading 60% when pressed fully. Tried swapping with a known good throttle pedal and same issue
Does the pedal need to be calibrated when fitted? Or am I looking at a wiring issue?
Any tips welcome
Thanks
Post #969987 4th Nov 2022 11:47pm
dannyragsdale
Papau New Guinea 2012 Defender 110 Puma 2.2 HT Fuji White
I have a similar issue and I'd be curious if anyone has an answer.
Post #972218 24th Nov 2022 12:43pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
check the low range sensor on the transfer box. when the ecu thinks you are in low it changes the mapping to what you are describing Roaming around 🇳🇴🇨🇭
Post #972235 24th Nov 2022 3:19pm
Clutch switch possible, bridge it to see if it is culprit you’ll soon know.
If it seems better all of a sudden, leave it bridged or replace clutch switch.
I can’t say it is that, but worth investigating as clutch switch cuts torque and can cause a rev hang as well. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #972283 24th Nov 2022 9:56pm
dannyragsdale
Finally got around to bridging the clutch switch and made a world of difference. The throttle responds immediately and doesn't hang anymore. Thanks for that tip!
Not sure if it's me getting used to the difference in response now, but the throttle is pulsing now. It doesn't do it all the time, but I either have to put my foot into the throttle or let off completely to not pulse. There doesn't seem to be an in between. Any thoughts on that? Thanks!
Post #974808 15th Dec 2022 11:38pm
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I spent nearly a year tracking down a pulsing throttle on my 2.2. Turned out to be wear on the loom where it comes through under the body, rubbing against the tub. Had worn through and was shorting on the bodywork.
Worth checking out as it was easy to spot once worked out.
Post #975403 21st Dec 2022 9:36pm
